New Reply
Cryogenic Insulation
Share Thread Thread Tools
May19-11, 12:20 AM   #1
I was hoping there is somewhere on here that can help
Im working on a project designing a superconducting transformer
currently i have to report possible options to use. Does anyone have any experience with cryogenic insulation if so what can you recomend.
It looks like glass microspheres or pearlite in a vacuum is going to be the best option.
also there is aerogel but I am having trouble finding a supplier, we are trying to stay away from MLI as the aluminium will induce eddy currents...
So What Im asking is does anyone have information on cost or sourcing these materials or another alteranatives?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
May19-11, 06:27 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
What temperature are you trying to maintain?
If the aluminum causes eddy currents, then aren't stainless steel walls also going to be an issue? I'm assuming the insulation is going to be vacuum insulation, and you're just asking about what to put inside that vacuum. Needless to say, MLI is the best option for that but you need to be able to pull a vacuum.
May19-11, 12:29 PM   #3
expanded foams
gas-filled poweders and fibrous materials
vacuum alone
evacuated powders and fibrous materials
opacified poweders
multilayer insulation
those are some of the main insulation options listed in order of increasing performance and increasing cost. not sure about cost or sourcing
May19-11, 10:11 PM   #4
77 K temperature, it will be made of g10 composite and will have a vacuum,
we are trying to minimize the heat loss as much as possible as it takes about 30 times the energy to cool every watt when using cryopumps at that temperature.
ive also seen LCI layered composite insulation on the net from NASA.
it looks like it will be a choice of powder or mli.
New Reply
Thread Tools
Similar Threads for: Cryogenic Insulation
Thread Forum Replies
Cryogenic Op Amp Electrical Engineering 1
Cryogenic Tanks Materials & Chemical Engineering 4
Cryogenic components Electrical Engineering 10
Cryogenic cirquits Electrical Engineering 2
Cryogenic Materials for Bladder Materials & Chemical Engineering 5
