Help: unit-step response of a first order system
The discussion focuses on determining the parameters 'a' and 'K' for a first-order system represented by the transfer function G(s) = k/(s+a) in response to a unit step input. The user successfully derived the relationships between 'a', 'K', and the time intervals t1 and t2, concluding that both parameters equal 10, resulting in G(s) = 10/(s+10). MATLAB was utilized to verify the solution, confirming its accuracy.
  • Understanding of first-order system dynamics
  • Familiarity with transfer functions and Laplace transforms
  • Proficiency in MATLAB for system analysis
  • Knowledge of unit step response characteristics
  • Study MATLAB's Control System Toolbox for advanced analysis
  • Learn about the stability criteria for first-order systems
  • Explore the concept of time constants in system response
  • Investigate the effects of varying 'K' and 'a' on system behavior
Control engineers, system analysts, and students studying control theory who seek to understand first-order system responses and parameter estimation techniques.
Jonny2011
A first-order system
G(s)=\frac{k}{s+a}
and its response to a unit step input are shown in the figure below.
Determine the system parameters a and K
2. The attempt at a solution
I’ve tried to find K & a using MATLAB and read a lot but didn’t find the right topic about this problem. I need hints guys to solve .
u(t) \Longleftrightarrow \frac{1}{s}
y(t)=x(t)*h(t) \Longleftrightarrow X(s)H(s)
Y(s) = \frac{k}{s(s+a)}=\frac{k}{as}-\frac{k}{a(s+a)}
\frac{k}{as}-\frac{k}{a(s+a)} \Longleftrightarrow \frac{k}{a}(1-e^{-at})
Now, it seems you have a tangential line and knowledge for what change in time it takes for that tangent to arrive to the maximal height of your output. So let derive an answer from this given:
We shall call the function for the tangent z(t) to avoid confusion with my previously used y(t). Thus:
z - z_1 = m(t - t_1)
z_1 = y(t_1) = \frac{k}{a}(1-e^{-at_1})
m = y'(t_1) = ke^{-at_1}
Plugging in the last two into the first:
z - \frac{k}{a}(1-e^{-at_1}) = ke^{-at_1}(t-t_1)
We then solve for what new time, t_2, will give the maximal height, which is z = k/a:
\frac{k}{a} - \frac{k}{a}(1-e^{-at_1}) = ke^{-at_1}(t_2-t_1)
t_2 = \frac{1}{a} + t_1
or
t_2 - t_1 = \Delta t = \frac{1}{a} \rightarrow a = \frac{1}{\Delta t}
We then need simply to apply the known maximal height of one to solve for k:
\frac{k}{a} = 1 \rightarrow k = a = \frac{1}{\Delta t}
thank you that was really helpful.
so we have t1=0 & t2=0.1 by applying the a=k=1/t2-t1
we get a=k=10
G(s)=\frac{10}{s+10}
I checked it in MATLAB and it was correct.
9K
