How Does Buoyant Force Influence Water Flow Through a Hole in a Sinking Bowl?
The discussion revolves around an experiment involving a rounded bowl with a hole placed in still water, exploring how buoyant force influences the water flow through the hole as weight is added to the bowl. The original poster is investigating the relationship between added weight, buoyant force, and the rate at which water enters the bowl through the hole.
  • The original poster attempts to understand the mechanics behind the water entering the bowl, questioning the role of buoyant force and whether it is uniformly distributed across the bowl's base. Participants also discuss the impact of water pressure at different depths on the phenomenon.
The discussion is ongoing, with participants providing insights into the relationship between buoyant force and water pressure. There is an exploration of whether the buoyant force is evenly distributed and how depth affects pressure, indicating a productive exchange of ideas without a clear consensus yet.
The original poster seeks background theory beyond Archimedes' principle to enhance their understanding of the experiment, indicating a desire for deeper conceptual clarity.
newmessiah
so i have an to do an EEI for an assignment due this friday. My experiment involves me putting a rounded bowl with a flat bottom and a hole in the center on the bottom onto some still water and testing how the bowl sinks faster as weight is added to the bowl. The water comes up through the hole in the bottom of the bowl, filling it from the bottom, faster as i add more weight. i am assuming this is because i am displacing more water as weight is added so there will be a greater buoyant force acting upwards but i don't fully understand why the water is coming up through the hole. is the buoyant force spread equally along the whole bottom of the bowl making it come through the hole because there is nothing solid to stop it from coming upwards (can i work out how many Newtons of force are making the water come up through the hole, if i measure the area of the bottom of the bowl/the volume of displaced water etc.)
are there any other physics concepts i need to know other than Archimedes' principle to fully understand this phenomenon?...any background theory information will be greatly appreciated! Thanks
buoyant force = weight of fluid displaced
Bowl + Hole in bottom = Sinking Bowl
Welcome to Physics Forums newmessiah :smile:
Well, the water pressure increases with depth. The hole is at some depth, below the top surface of the water. Something along those lines should probably come into your explanation.
thanks for that!
do you know if the total buoyant force would be spread equally over the base of the bowl?
Well, the buoyant force comes from the pressure being different at different water depths (higher pressure at deeper depths). Is the base of the bowl all at the same depth?
9K
