Continuum Conversion of Lattice Points via Taylor Series Expansion
The discussion focuses on converting an array of lattice points into a continuum using Taylor series expansion, specifically addressing the transformation from discrete systems to continuous ones. The lattice distance, denoted as λ, plays a crucial role in this conversion. The conversation highlights the relevance of this transformation in the context of spin excitations, particularly magnons and solitons, observed under low temperature and long wavelength limits. The participants seek clarity on the application of Taylor series in this context.
  • Understanding of Taylor series expansion
  • Familiarity with lattice point systems
  • Knowledge of spin dynamics and excitations
  • Concept of continuum mechanics
  • Research the application of Taylor series in physics, particularly in continuum mechanics
  • Explore the behavior of spin excitations in lattice systems
  • Study the properties of magnons and solitons in low temperature environments
  • Investigate mathematical techniques for transitioning from discrete to continuous models
Physicists, mathematicians, and researchers interested in the mathematical modeling of physical systems, particularly those studying spin dynamics and continuum mechanics.
saravanan13
I consider an array of lattice points and construct a vector at each lattice points.
How to convert this discrete system into a continuum one by using the Taylor series expansion by considering the lattice distance say [tex]\lambda[/tex]?
thanks in well advance?
I'm afraid you're making no sense to me...
Care to give some more information?
I meant to say mostly Taylor series is regarded as transformation from discrete system to continuous one. In that sense how can I convert the discrete lattice to continuum one under certain approximation?
This type of problem one can observe spin excitation in the form of magnons and soliton under low temperature and long wavelength limit.
So all the spins in the lattice I consider as a spin vector with lattice distance lambda.
This spin can excite in the low temperature and long wavelength limit and excitation in the form of magnons or solitons.
  • · Replies 17 ·
