Calculating Force Applied to Wall with 1st & 3rd Laws
  • Context: Undergrad
  • Thread starter Thread starter Alem2000
    Laws
The discussion focuses on calculating the force required to keep a particle with a mass of 3.0 kg from falling against a wall, considering static friction with a coefficient of friction (μ_s) of 0.7. The normal force (η) is determined to be equal to the gravitational force (mg), and the frictional force (F_f) is calculated as F_f = μ_s * η. According to Newton's third law, the push force (P) exerted on the wall is equal to the normal force, and for the particle to remain stationary, the gravitational force (F_g) must equal the frictional force (F_f), leading to the conclusion that P = η = mg.
  • Understanding of Newton's First and Third Laws of Motion
  • Knowledge of static friction and its coefficient (μ_s)
  • Basic concepts of force, mass, and acceleration (F=ma)
  • Ability to perform vector analysis in physics
  • Study the application of Newton's Laws in static equilibrium scenarios
  • Learn about calculating forces in two-dimensional vector systems
  • Explore the concepts of friction in different materials and conditions
  • Investigate advanced applications of static friction in engineering contexts
Physics students, mechanical engineers, and anyone interested in understanding the principles of force and motion in static systems.
Alem2000
I had a question about a particle with mass [tex]m=3.0kg[/tex] if you take
this mass and push it up against a wall how much force would you have to
apply to keep it from falling if you had [tex]\mu_s = .7[/tex]? where [tex]\eta<br /> [/tex] is the normal force and [tex]P[/tex] is the push force what I did was apply the first and 3rd laws my
equations came out to be
[tex]\eta=mg[/tex] and [tex]f_k=P[/tex] now after I calculate this I know I have to do something next b/c of the 3rd law. Do I draw in vector form the push exherted on the wall and the the push that the wall exherts back and add the (by taking the negative vector and reversing it to make it posative) I am a little confused?
What keeps particle from falling is the friction force [tex]F_{f}[/tex] which is equal to [tex]F_{f}=\mu_{s}\eta[/tex]. On the other side, from 3rd law you know that [tex]P=\eta[/tex] and that in order for particle not to fall must be [tex]F_{g}=F_{f}[/tex], where [tex]F_{f}=mg[/tex]. When you push the body pushes the wall with force [tex]P[/tex], so vector [tex]P[/tex] "attacks" wall. What Sir Isaac Newton says in his 3rd law is tha walls makes a "counter attack" on particle with force of the same intensity and direction as [tex]P[/tex], only in different way and this reactive force acts on a particle, and not on a wall. I hope this is what you wanted to know.
  • · Replies 24 ·
  • · Replies 77 ·
  • · Replies 18 ·
  • · Replies 35 ·
  • · Replies 18 ·
  • · Replies 61 ·
