New Reply
Dynamo to charge battery using electromagnet.
Share Thread Thread Tools
May25-11, 09:34 AM   #1
A team on The Apprentice have to come up with a new electrical device. They propose a hand cranked dynamo to charge a battery which initially uses the residual charge in the battery to power the electromagnet, instead of a permanent magnet (the idea being that this reduces the weight of the device by removing the need for an iron core). Once current is flowing this is then used to power the electromagnet as well as charging the battery. A sketch of the circuit is shown in the attachment. Making reasonable assumptions about its size, the number of turns in the induction coil and in the dynamo coil, discuss the feasibility of the device. (I can't upload the sketch here, but basically it has the dynamo coil, the dynamo and the circuit resistance all in series)
2. Relevant equations
3. The attempt at a solution
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
New Reply
Tags
dynamo, electromagnet, induction
Thread Tools
Similar Threads for: Dynamo to charge battery using electromagnet.
Thread Forum Replies
Electromagnet pulse coil powered by static charge Electrical Engineering 6
Battery charge Introductory Physics Homework 18
First battery charge Computers 4
charge from dynamo Electrical Engineering 1
Charge on capacitors each with a battery Introductory Physics Homework 8
