Is there a spectrum difference in amplitude modulation with a sine or cosine?
The discussion centers on the frequency spectrum differences when modulating a pulse X(t) with a sine wave versus a cosine wave. The frequency spectrum expressions derived are \frac{1}{2j}[X(f-f_0)-X(f+f_0)] for sine modulation and \frac{1}{2}[X(f-f_0)+X(f+f_0)] for cosine modulation. The observed difference in magnitude spectrum is attributed to the phase shift of \pi/2, which complicates the transformation between the two cases. The speaker concludes that the phase shift does not translate as expected due to the opposite phases of the components in the sine case.
  • Understanding of amplitude modulation principles
  • Familiarity with Fourier transforms
  • Knowledge of phase shifts in signal processing
  • Basic concepts of frequency spectrum analysis
  • Study the implications of phase shifts in Fourier transforms
  • Explore the differences between sine and cosine modulation in signal processing
  • Learn about the mathematical properties of complex exponentials in modulation
  • Investigate the effects of modulation on signal integrity and spectrum analysis
Signal processing engineers, communications specialists, and students studying modulation techniques will benefit from this discussion.
DragonPetter
If I modulate a pulse X(t) with a.) a sine wave or b.) a cosine wave, I have the frequency spectrum expressions
[tex] a.) \frac{1}{2j}[X(f-f_0)-X(f+f_0)][/tex]
[tex] b.) \frac{1}{2}[X(f-f_0)+X(f+f_0)][/tex]
When I plot these for a pulse, I see a difference in the magnitude spectrum, but I should not expect to see this since this is simply a phase shift of [tex]\pi/2[/tex]
I would think if I multiplied b.) by [tex]e^{-j\pi/2}[/tex], I would get what I see in a.) but this is not the case.
Can anyone help me with what I'm missing?
Ok, I'm guessing the phase shift e^-jpi/2 does not extract out so nicely as I thought for the a.) case when the sine Fourier transform is taken. The two components X(f-fo) and X(f+fo) will have opposite phases unlike in b.) so I cannot simply multiply b.) by a phase shift to get to a.)
  • · Replies 0 ·
