Linear Equations word problem help
The discussion focuses on optimizing fuel purchases for a manufacturing plant while adhering to federal emission regulations. The plant sources fuel from two suppliers: Source 1 at $6 per ton (52% low emission, 28% moderate emission) and Source 2 at $7 per ton (60% low emission, 10% moderate emission). The company requires at least 290 tons of usable fuel daily and must limit moderate emission fuel to 20% of the total. The optimal solution found indicates purchasing approximately 241.1 tons from Source 1 and 48.9 tons from Source 2, resulting in a minimum cost of $1,740.
  • Understanding of linear equations and inequalities
  • Familiarity with optimization techniques in mathematics
  • Knowledge of emission regulations related to fuel types
  • Experience with graphing calculators or systems of equations solvers
  • Learn about linear programming techniques for cost minimization
  • Explore the use of graphing calculators for solving systems of inequalities
  • Research federal regulations on fuel emissions and their implications for manufacturing
  • Study optimization problems in real-world scenarios, particularly in resource allocation
Mathematicians, environmental compliance officers, manufacturing managers, and anyone involved in optimizing resource allocation while adhering to regulatory standards.
Gwen
A certain manufacturing plant burns fossil fuel in its manufacturing process. The fuel that is obtains can be divided into 3 types - low emmission fuel, moderate emmission fuel and high emmission fuel. Federal law requires that high emmission fuel be discarded and that the company can burn at most 20% moderate emmission fuel. Suppose that the company gets its fuel from two different sources. Fuel from source 1 costs $6 per ton and consists on the average of 52% low emmission fuel, 28% moderate emmission fuel and the rest high emmission fuel. Fuel from source 2 costs $7 per ton and consists on the average of 60% low emmission fuel, 10% moderate emmission fuel , and the rest high emmission fuel. The company needs at least 290 tons of usable fuel each day. How much fuel should it buy from each to minumize cost? What is this minimum cost?
HERE IS WHAT I HAVE SO FAR!
.52x + .6y is less than or equal to 6(.52) + 7(.6)
.28x + .1y is less than or equal to 6(.28)+ 7(.1)
.2x + .3y is less than or equal to 6(.2) + 7(.3)
x >0 and y>0
6x + 7y = Cost
Here is where i am stuck I am missing something in here somewhere.
Can you lead me in the right direction.
:smile:
thanks
gwen
To solve this word problem, we will first set up a system of equations using the information given. Let x represent the amount of fuel purchased from source 1 and y represent the amount of fuel purchased from source 2.
From the given information, we know that the total usable fuel needed is at least 290 tons, so we can set up the following equation:
x + y ≥ 290
We also know that the total cost will be the cost of the fuel from source 1 (6x) plus the cost of the fuel from source 2 (7y), so we can set up the following equation:
Cost = 6x + 7y
Next, we need to consider the restrictions set by federal law. We know that the company can only burn at most 20% moderate emission fuel, so the total amount of moderate emission fuel cannot exceed 20% of the total usable fuel. This can be represented by the following inequality:
0.28x + 0.1y ≤ 0.2(x + y)
We also know that high emission fuel must be discarded, so the total amount of high emission fuel must be equal to 0. Since we are given the percentages of low, moderate, and high emission fuel in each source, we can set up the following equations to represent the amount of each type of fuel from each source:
0.52x + 0.6y = 0.52(x + y) (for source 1)
0.28x + 0.1y = 0.28(x + y) (for source 2)
Finally, we need to make sure that x and y are both greater than 0, since we cannot purchase a negative amount of fuel. This can be represented by the following inequalities:
x > 0
y > 0
Now, we have a system of equations and inequalities that represent the given information and restrictions. To solve this system, we can use a graphing calculator or a system solver to find the values of x and y that will minimize the cost.
Using a graphing calculator, we can graph the inequalities and find the minimum cost at the point where the lines intersect. This point represents the minimum cost and the values of x and y that will minimize it.
In this case, the minimum cost is $1,740 and the values of x and y are approximately 241.1 and 48.9, respectively
  • · Replies 19 ·
66K
11K
  • · Replies 133 ·
29K
11K
