New Reply
what is a "charge"?
Share Thread Thread Tools
May26-11, 10:09 AM   #1
what is a "charge"?
hi,
what exactly is a charge? how do you define it? why is a positively charged ion at a higher potential difference than a negatively charged ion? why is work needed to be done on a positively charged ion to move it out of an electric field of another positively charged ion?
i'm very confused with electricity, and i hope i can understand it better if these doubts get cleared :)
thanks in advance
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
May26-11, 10:48 AM   #2
See this, I think it will shed some light on your questions.
http://www.youtube.com/watch?v=wMFPe-DwULM
May26-11, 11:23 AM   #3
Quote by AudioFlux View Post
hi,
thanks in advance
Nobody understands charge. We can only describe it, indirectly.
In fact, the entire universe is composed of energy, but nobody has the foggiest idea what regulare energy actually is, much less "dark energy" if that exists. That's why physics is great fun. You can make up the most outlandish theory you want and nobody can prove you wrong. They can only present an argument against your theory.
May26-11, 04:29 PM   #4
Recognitions:
Gold Membership Gold Member
what is a "charge"?
Quote by Zentrails View Post
I think you should look up the definitions of energy and scientific theory. One cannot simply make up theories, they must have very good reasons.
May26-11, 04:36 PM   #5
Recognitions:
hi,
thanks in advance
A charge is simply the force produced by a charged particle on other charged particles. Electromagnetic charges have a + and a -, aka postitive and negative.
A positive ion that is moved out of an electric field of another ion is having work done to it by that ion. Or more accurately both ions repel each other, performing work on each other and transforming potential energy into kinetic energy.
See here for more info: http://en.wikipedia.org/wiki/Electric_charge
May26-11, 06:15 PM   #6
Electric charge is a theoretical given. It is an unexplained starting point for theoretically explaining special effects. Theoretical explanations may or may not be correct. They are educated guesses. No one knows what electric charge is. We do know a great deal about its effects. Those effects are seen as patterns in changes of velocity. We know neither the origin of electric charge or of polarity.
James
May26-11, 06:18 PM   #7
Recognitions:
Quote by James A. Putnam View Post
James
Please, don't start this again, you will only confuse the OP and others even more. We have a definition of charge which explains what the OP is asking. I suggest you defer to that unless someone wants to talk about theoretical physics or something.
May26-11, 06:20 PM   #8
Recognitions:
James
Third thread in a row, really? And you ask why they get closed down.
The terms under physics are clearly defined, especially what the OP is asking.
May26-11, 06:21 PM   #9
A charge is a coupling constant characterizing the interaction between matter fields with the electromagnetic field.
May27-11, 12:12 AM   #10
you can think of charge as where the electric field lines end
May27-11, 05:18 AM   #11
thanks for your responses. let me elaborate my question, when we say an electron has a charge of -1.60217646 × 10-19 coulombs, what does it mean? is it like some sort of an energy or a virtual "thing"(or assumption) or is it something you can weigh?
May27-11, 05:27 AM   #12
Recognitions:
The coulomb (symbol: C) is the SI derived unit of electric charge. It is defined as the charge transported by a steady current of one ampere in one second.
The problem with measuring charge, is that the closer you get to the particle the larger the force is. So instead of just saying the force is X amount at X distance, it was defined by the number of charged particles that move across a point when 1 volt is applied for 1 second.
May27-11, 09:47 AM   #13
Charge is just a name to describe the properties of electrostatic interactions. Just like mass, what can you say about mass?
Positive charges do work when they move closer is due to the electrostatic repulsion between charges. When forces move a distance in the direction work is done. Again you cannot explain why, just like why gravity is always attractive? Yes, you can use quantum mechanics (Relativity also for gravity) and string theory, but still you cannot explain quantum mechanics.
Coulomb is just a SI unit from convention, derived from Ampere defind by Ampere times second. Again and again you cannot ask why, just like asking what does it mean by I have mass of 60kg. It's just measured using the unit. If you use a banana to describe the charge of a proton, then electron just have -1banana of charge. It's just a relative measure used to compare the property of objects.
May27-11, 12:33 PM   #14
it means that that is how many electric lines of force end at that point
each line can be thought of as having a tension along its length and it repels all other lines.
all lines must end at charges.
http://www.google.com/search?q=electric lines of force
http://en.wikipedia.org/wiki/Line_of_force
May27-11, 02:20 PM   #15
Quote by Drakkith View Post
OK, here's what WIKI says:
https://secure.wikimedia.org/wikipedia/en/wiki/Energy
There doesn't seem to be any "scientific theory of energy."
Energy is an abstract concept that helps us conceptualize theories based on the results of scientific experiments.
Theories do one thing and one thing only: they predict future events.
It's not what you are taught in high school, but that's the truth about theories.
Nobody has the foggiest idea what energy actually is.
That's not a theory, it's an opinion.
May27-11, 03:16 PM   #16
Mentor
Please do not CHANGE this thread into ANOTHER ad nauseum thread on "what is energy?".
Zz.
May27-11, 04:19 PM   #17
Quote by ZapperZ View Post
Zz.
OK, sorry.
New Reply
Tags
charge, current, electricity, ion
Thread Tools
Similar Threads for: what is a "charge"?
Thread Forum Replies
In binary can we have a value with "deci" "centi" "mili" or more lower valued prefix? Computers 14
Electric potential at point x on the axis of a ring of charge density "eta" Introductory Physics Homework 2
total charge lifted by the "charge escalator" Introductory Physics Homework 6
Difference between "Identical", "Equal", "Equivalent" Calculus & Beyond Homework 9
In the Electric field of a Continuous Charge Distribution, what is "conti.." exactly? Electrical Engineering 2
