Classical Physics & Electron Mass: F=ma?
  • Context: Undergrad
  • Thread starter Thread starter Rockazella
    F=ma
The discussion revolves around the applicability of classical mechanics, specifically the equation F=ma, to electrons and other atomic-sized systems. Participants explore the validity of classical physics in the context of quantum mechanics and relativistic speeds, addressing both theoretical and practical implications.
  • Some participants argue that F=ma is valid at all times, but with caveats regarding relativistic speeds where mass may vary.
  • Others contend that at high speeds, the relationship should be expressed as F=dp/dt, emphasizing the importance of momentum over classical force.
  • There is a suggestion that applying classical force concepts to electrons is problematic due to their wave-like nature and dependence on quantum states.
  • Some participants propose that classical equations can be used when wave properties are negligible, such as in semiconductor mobility calculations.
  • Disagreement exists regarding whether an electron can be considered a wave or a particle, with some asserting it is neither, while others maintain it has wave-like properties.
  • Concerns are raised about the implications of mass variability in classical equations, particularly in scenarios involving rockets or particles losing mass.
  • A participant questions the meaning of mass in the context of F=ma and seeks clarification on the definitions of momentum and time.
Participants do not reach a consensus; multiple competing views remain regarding the applicability of classical mechanics to electrons and the interpretation of their nature.
Limitations include the dependence on definitions of mass and momentum, the unresolved nature of relativistic effects, and the varying interpretations of quantum mechanics and wave functions.
Rockazella
I know that QM must be used to describe atomic sized systems, but is classical still applicable? Take an electron for example. I don't the the mass of an electron so I'll just say its m=x. If an electron were to have a force of 10N applied to it, would its acceleration be 10/x, or do these equations have no use at this size?
F=MA is equally valid at all times. But there is a catch - at high relativistic speeds, the variation of M is enough to notice.
F = dp/dt = rate of change of momentum. Theoretically, this should apply to all sorts of things - including impacts with photons.
Actualy you can't really think of applying a force like that to an electron. It doesn't make much sense because its a wave. The action of the electron to a froce very much depends on the state of the electron.
Blah, F=ma is a bad thing to try to apply at relativistic speeds, since transverse and longitudinal inertia are different at relativistic speeds. F=dp/dτ is the way to go!
This depends on what kind of accuracy you're interested in. If the particle is moving at relativistic speeds, i.e. close to the speed of light, then the force is not related to the acceleration as F = ma. It's given by F = dP/dt where P = mv = m_o*v/sqrt[1 - (v/c)^2] (m_o = electron rest mass). If the speed is not relativistic, i.e. v << c, then F = ma will work fine and there's no distinction between m and m_o. These are classical concepts. For example: In particle accelerators where particles are travel at almost the speed of light, then the particles leave tracks in bubble chambers and you can actually see the trail of bubbles - there are of course different ways of detecting the paths of particles.
If you're talking about the trajectory on the quantum level then a trajectory has little meaning. One then speaks in terms of quantum states or what many people call a "wave function." The "wave" has meaning only on a statistical basis though.
Pete
F = ma is wrong. It'd equal to dp/dt in many cases. In those cases F = ma is an equality.
At the quantum level F = ma is meaingless. If a particle is loosing mass then F = ma is wrong. The correct equation is F = dp/dt
Pete
The force is used in quantum mechanics in the sense of a potential energy function. i.e. the F in F = -grad V is not used by the V is.
And an electron is not a wave. An electron has a wave function associated with it and then it has meaning only in a statistical sense.
Pete
You can use classical equations if the wave properties of the particle (i.e the electron) are not important for the problem. Example: Calculation of the electron mobility in a semiconductor. Habitually this a first approach, semi-classical.
But, if you must take in consideration the wave properties, you should use a quantum mechanics expression involving the wave function of the particle. Example: Calculation of bands in a semiconductor.
An electron is a 'wave', and the 'wave function' certainly has more meaning than statistical. The reason it isn't actualy a wave is because we don't solve a wave equation, but a different equation.
No. The electron is not a wave. It's not a particle. It's not either. It's something else. Some people use the term "wavicle" but not I.
And no. The wave function has only a statistical meaning. For example: If the wave function of a particle is Psi(x,t) then the meaning of this is defined as follows. The quantity
P = |Psi(x,t)|^2 dx
is the probability that, if the postition of the particle is measured then the probability that the particle will be in the interval of width dx center at x at the time t is P. The quantum state is a quantity which contains all the information about the particle. All this information is of a statistical nature.
I created this page
http://www.geocities.com/physics_world/qm/probability.htm
to describe the meaning of a quantum state using die as an example. It's not a perfect analogy since the die are not quantum particles - but it gives you the idea of what it means
Pete
I thought the commonest description is of "both, but not at the same time".
Pete
My QM isn't very good - can you give me some more? Why would "m" being a variable make f=ma wrong? If the mass goes up due to high relativistic speed, can't you just plug that new mass back into the equation? What do you mean by losing mass? And what are "p" and "t": position and time?
Sure, you wouldn't want to integrate the acceleration function into a velocity or position function, but at an instantaneous time, I don't see why you can't still use it to find instantaneous acceleration. Or why couldn't you just insert the equation for relativistic mass in place of "m" and end up with valid acceleration, velocity, and position functions?
An electron is ALWAYS a 'wave'. It is only modeled as a particle at the classical limit, rather like Newtons laws are used at non-relativistic limits. The only reason for making such an approximation is to make the math easier.
The variation of mass makes F=ma inexact at the classical level. It’s not necessary to take in consideration relativistic scenarios or QM ones.
One of the typical examples is a rocket. The propulsion force is acting over a system which is losing mass (the propellant burned).
The Force acting over a particle is:
F= dp/dt where p is the momentum and t is the time.
p = mv by definition of momentum, where m is the mass and v the velocity.
That is: F = vdm/dt + mdv/dt
Usually the first term is null because the system doesn’t change their mass (we obtain F=mdv/dt=ma). But in the rocket example, you must take in consideration the two terms.
That's not what I meant. For f = ma to be meaningful the "a" has to be meaningful. Acceleration is defined in terms of the particle's position as a function of time. However in quantum mechanics one cannot do this. A particle does not have a classical trajectory. It's not possible to determine the particle's position as a function of time because that would mean continuous measurements of the particle's precise location. But the position can't be measured precisely without the momentum being affected. Classically you can picuture this as everytime you measure the position the velocity changes. The end-all is that it's not meaningful to speak of a trajectory and therefore it's not meaningful to speak of acceleration. It's only meaningful to speak of averagges. For example: If <p> is the average momentum and the particle is moving in a potential V then the equation of motion is found using Ehrenfest's theorem which is
d<p>/dt = <-grad V>
As far as loosing mass I was referring to the use of f = ma in general in mechanics. You shouldn't think of this as the definition of force - For example: Suppose you wanted to cqalculate the position of a rocket as a function of time given a certain inittial mass and thrust etc. If you try to use f = ma you'll get the wrong answer. The mass of the rocket is constantly decreasing. The correct formula is f = dp/dt.
How would you measure the acceleration?
Or why couldn't you just insert the equation for relativistic mass in place of "m" and end up with valid acceleration, velocity, and position functions? [/B]
You'd get the wrong result. The expression F = ma is not relativistically correct. If you want to express the force as a function of accleration then you'd have to express it in terms of longitudinal mass M(L) and transverse mass M(T) (Transverse mass happens to be equal to relativistic mass().
M(L) = m_o[1-(v/c)^2]^(3/2)
M(T) = m_o[1-(v/c)^2]^(1/2)
Let A(L) = component of acceleration vector parallel to the direction of motion
Let A(T) = component of acceleration vector transverse to the direction of motion
F =M(L)A(L) + M(T)A(T)
Pete
The electron is not a wave. It's not a particle. It's neither. Do you have the Feynman Lectures? From V-III pagbe 1-1
Newton thought that light was made of particles, but then it was discovered that it behaves like a wave. Later, however (in the beginning of the twentieth century), it was found that light did indeed sometimes behave like a particle. Historically, the electron, for example, was thought to behave like a particle, and then it was found to behave like a wave. So really it behaves like neither. Now we have given up. We say: "It is like 'neither'"
There is one lucky break, however - electrons behave just like light. The quantum behavior of atomic objects (electrons, protons, neutrons, photons, and so on) is the same for all, they are "particle waves," or whatever you want to call them. So what we learn about the properties of electrons (which we shall use for our examples) will apply also to all "particles," including photons of light.
Every time an electron is detected its a single entity, not part of something like one gets with a wave. So when an electron is detected its behaves like a particle. However if you run a large number of experiments then what you'll find is that the measurements of the postion of the electron, in general, have a wave pattern to them - and that includes interference. And the interference pattern is there even when the electron can't interact with another electron in the experiment.
So Feynman is quite right when he says that an electron is neither a particle nor a wave. And most physicists agree with that. I know of now quantum mechanics text which states differently. (there is Bohm's theory though but it's largely rejected)
Pete
Actually the opposite is true. An object 'is' what it behaves like. The precise description is to say that it's neither a particle nor a wave.
How it behaves depends on the experiment and how what you're measuring. See my post where I quote Feynman - he's about the most accurate that I can find on this topic and I agree with him 100%. Every single quantum mechanics text I have or have ever used says the same thing.
Pete
Forces and electrons
Tunnelling in quantum mechanics makes a mockery of the idea of a force.
You can see the wave nature of an electron with just one electron, you don't need many. In physics a thing is what we model it as. An electron can always be modeled as a wave, and sometimes as a particle if certain approximations are good. Therefore the electron is a wave according to the accepted fundamental(rather than approximate) model. Its particulate nature only comes about when we ask classical questions about it. The wave function is the shape of the electron, it does not just give us the probability of finding the electron. You can interpret the whole thing differently like Bohm, so then the electron is a particle and the wave function some quantum interaction term. This gives even more meaning to the wave function. This interpretation is usually ignored because it requires the quantum potential, which comes from nowhere. Feynman knew the electron was a wave, he even expands wave functions in terms of trajectories which are sometimes classical and sometimes not. Part of his work describes how the wave function gets to a classical limit, but it is still a wave function.
Well that's just it - the mass of the rocket decreases at a known rate (kt) that you can apply to the formula f=ma. Substitution gives you f=(m-kt)a. You can still integrate that into an accurate position function. I'm sure I did exactly this problem in high school physics (or maybe calculus).
I don't want to measure it, I just want to mathematically model it.
Ok, that makes a lot more sense - I thought an electron was big enough to model using rough Newtonian motion. I realize when around an atom, there is no definable position function (hence electron "cloud"). But what about when free and say fired from an electron gun? Does this affect the resolution of a TV?
That's not quite correct. A single electron does not display wwave properties. And the wave cunction is not the shape of an elecron by any means whatsoever.
No offense but I'm afraid that you have some serious misconceptions about quantum mechanics.
Pete
See web.media.mit.edu/~sibyl/projects/cognition/science/rocket.html
I don't want to measure it, I just want to mathematically model it.[/B]
Its not that simple in quantum mechanics. In fact its a crucial point. If you can't state exactly how to measure it in principle then it's not meaningful - that's the lesson of quantum mechanics. This is very different from Newtonian mechanics.
More later
Well I guess you have to decide if you believe an electron is a wave or a particle for yourself. All I know for fact is that if you simply view the electron as a wave, you can get all the answers you want. This is more of a preffered view than anything real. Of course we can't talk about anything real, because we are only in the business of modeling reality.
And single electrons do exhibit wave properties. A single electron will diffract, or undergo Bloch oscilation, or tunnel...
Pete
Yes, in the standard (Copenhagen) intepretation, the wavefunction has no physical analogue, but in the De Broglie-Bohm theorum you get 'matter waves'.
A single electron does not exhibit wave properties per se. Only a large number of identical experiments each with a single electron, or a large number of electrons in a single experiment will wave characteristics manifest themselves. Tunneling is a quantum effect with no mechanical analogy. But it can be envisioned as single particle violated energy conservation but consistent with the time-energy uncertainty principle.
As far as difraction goes - Let me use Young's double slit experiment. A source of light is directed towards the double slit. The source is very weak. On the screen behind it the location of the photon is registered. The source is adjusted so that only one photon is registered at a time. But only one photon is detected and as such it is not a wave. In fact that's about what one would expect for particles. I.e. if a beam of particles impinges on a single slit then there is a spread of particles on the screen. But only *one* particle does not show any wave property. However if the experiment is done a large number of times and each 'photon detection' location recorded then in the analysis the data will show a diffraction pattern. Or you can do the experiment once but have a large number of experiments done with a single photon and the results compared - then there's a diffraction pattern. The pattern is clearly defined by the wave-function and only then as a probability distribution
But not a single particle - that's why they call it the wave-particle duality
Pete
  • · Replies 19 ·
  • · Replies 41 ·
