Thermodynamics of an elastic band
The discussion revolves around the thermodynamics of an elastic band, specifically focusing on the Gibbs free energy and its relation to entropy and tension. The original poster presents a problem involving the thermal expansion coefficient at zero tension, seeking to demonstrate that it is negative based on the provided equations.
  • The original poster attempts to show that the partial derivative of length with respect to temperature at constant tension is negative, using a Maxwell-type relation. Some participants question the correctness of the entropy expression and suggest it may contain a typo or require additional conditions.
Some participants confirm the correctness of the entropy expression as presented, while others propose a simplification of the expression. There is an ongoing exploration of the implications of the constants involved, particularly regarding the relationship between a and b.
Participants note that the problem is based on a past exam paper, which may impose specific constraints or assumptions relevant to the discussion.
bon
The Gibbs free energy of an elastic band satisfied dG = -SdT - LdF where F is the tension and L the string's length.
At fixed temp the entropy is given by S = So - a(L-Lo)^2 + b(L-Lo)^2
Where Lo is the length of the elastic at zero tension and a and b are positive constants.
Show that the thermal expansion coefficient at zero tension is negative.
So I'm trying to show that partial L wrt partial T at constant F < 0.
Using a maxwell-type relation we can say dL/Dt)f = dS/dF)T
But I'm not sure where to go from here..the expression for S doesn't contain F and I can't see how to solve..
thanks!
Is this part correct? It seems like an odd way of writing it; I suspect there's a typo or another condition in there somewhere.
It is correct yes! And no typo..this was on a past exam paper.
It doesn't seem odd that the entropy expression could be simplified to S = So + c(L-Lo)^2, where c = b-a? I don't see a way to solve it unless it's also assumed that a > b.
  • · Replies 19 ·
9K
  • · Replies 17 ·
