Designing Process for a Temperature Controlled Box
The discussion revolves around the design of a temperature-controlled box, focusing on calculating heat loss through the box's walls and exploring methods for maintaining a constant internal temperature. Participants discuss theoretical aspects, calculations, and potential components such as Peltier junctions and solar panels.
  • One participant estimates heat loss through a multi-layered box design, calculating a total heat loss of 457.71 W based on thermal conductivities and surface area.
  • Another participant challenges the initial calculations, suggesting that the heat transfer coefficients between the layers and the external environment were not adequately considered, implying that the power requirement may be underestimated.
  • A later reply acknowledges the errors in the initial conductance calculations and proposes a revised approach to determine overall conductance, resulting in a significantly lower heat loss estimate of 3.008 Watts.
  • One participant notes the need to adjust the temperature difference used in calculations, leading to a further revised estimate of heat loss through the walls of the box.
  • Participants express interest in using Peltier junctions and solar panels, indicating that while these methods may not be the most efficient, they are still considered for the design.
Participants do not reach a consensus on the initial calculations, with significant disagreement regarding the accuracy of the heat loss estimates and the factors influencing them. Multiple competing views remain on the appropriate methods for calculating heat loss and the feasibility of the proposed design components.
Limitations in the discussion include assumptions about the thermal properties of materials, the neglect of certain heat transfer coefficients, and the varying environmental conditions the box may face.
OsirisGuy
Hey all!
I am thinking of building a box in which the insides can be held a constant temperature. I would like to see if I can determine some parameters for the box.
My first step is to determine heat loss through the box. I'm estimating that the largest difference in heat will be 101°C (Ideally the temperature will be controlled by a PID)
The box will be 1 m3, And will have layers of
| 0.00635 m Plywood | 0.003175 m ABS Plastic | 0.00635 m air space | -
| 0.003175 m ABS Plastic | 0.00635 m Plywood | 0.003175 m ABS Plastic | -
| 0.00635 m air space | 0.003175 m ABS Plastic | 0.00635 m Plywood |
(After these layers, I will assume the surface area is now 0.830103 m2
Thermal Conductivity for Air = 0.024, Plywood = 0.13, ABS = 0.03; and to make things easier I figured Conductance (U) to be 1.0990 and using Fourier's Law [tex]Q = A\frac{DeltaT}{U}[/tex]
I come up with a heat loss of 76.285 Watts. I will just assume that this will occur on every side of the box, so I multiplied by the 6 sides for an estimated heat loss of 457.71 W.
I am now just wondering if my calculations are in the correct direction. Perhaps I am off by a little, but I hope to be heading in the right direction.
The next steps seem to be:
1. Using Peltier Junctions to provide temperature
2. Using a PID to automatically hold temperature at a desired temperature
3. Providing the power and source for the project (hopefully using a "green" method, e.g. solar panels).
Of course, most of this is still theoretical so although Peltiers and solar panels may not be efficient at the moment, I'd still like to incorporate it into the design. Consider this a scrap book or blueprints of sorts in my designing process.
So any takers? :biggrin: Thanks
You seem to have ignored the heat transfer coefficient between the walls of the box and whatever is inside and outside it. And also the HTC between the plywood and ABS, and the air gaps inside the walls.
Without including those effects, your results will not be off by "a little", they will be completely wrong.
Just from common sense, does it seem reasonable that you need 0.5kW of power to keep a 1m^2 well-insulated box 100C above ambient temperature? Think about the oven on your electric cooker, for example. (Your cooker is probably much less well thermally insulated than your box design).
See, this is why I asked :smile: Thanks for pointing out those errors.
So I misunderstood the calculation of my overall conductance (U), or the overall HTC. Breaking things down, it should be
[tex]UAir=\frac{1}{k Air}[/tex] [tex]UPlywood=\frac{dX Plywood}{k Plywood}[/tex] [tex]UABS=\frac{dX ABS}{k ABS}[/tex]
Then I can take my final Q to be
[tex]Q = A\frac{DeltaT}{UAir+UPly+UABS+UAir+UABS+UPly+UABS+UAir+UABS+UPly}[/tex]
Doing the math
UAir = 41.667 * 4 "Layers" (Inside Box, Air Space 1, Airspace 2, Outside Box) = 166.667
UPly = 0.049 * 3 "Layers" = 0.147
UABS = 0.106 * 4 "Layers" = 0.423
UOverall = 167.237
Using the same Area and Temperature difference as before
Q = 3.008 Watts which is much more different than my previous result.
I should note that this box may remain outside and will be subjected to a temperate climate. The box will need to be heated and cooled.
If this value is more accurate, then I'd like to say that using peltiers and solar cells is more relaistic for this project.
I realized I calculated my temperature difference from both extremes, instead of from a mid point to either extreme. My new DeltaT will be plus/minus50°C. Because of this I will only use one piece of 1/4" plywood (same thickness as before), and same dimensions.
Heat loss through one wall will be 0.5 W, so through 6 walls will be 3 W
  • · Replies 29 ·
