Solve V = 5 + 12*j in Form v(t) = A*cos(w*t) + B*sin(w*t)
  • Thread starter Thread starter anengstudent
    Phasors Sinusoids
The problem involves converting the complex number V = 5 + 12j into the form v(t) = A*cos(w*t) + B*sin(w*t) with w = 10000 rad/s. The correct transformation yields v(t) = 5*cos(w*t) - 12*sin(w*t). The solution utilizes the unit circle properties and the cosine of the sum of angles identity, specifically cos(α + β) = cos(α)cos(β) - sin(α)sin(β). The graphical approach confirms the solution by matching the plotted function with the derived equation.
  • Understanding of complex numbers and their representation
  • Familiarity with trigonometric identities, particularly cosine and sine functions
  • Knowledge of the unit circle and its applications in trigonometry
  • Basic understanding of angular frequency in oscillatory motion
  • Study trigonometric identities, focusing on the cosine of the sum of angles
  • Learn about the unit circle and its relationship to sine and cosine functions
  • Explore graphical methods for solving trigonometric equations
  • Investigate the implications of angular frequency in oscillatory systems
Students in physics or engineering courses, particularly those studying oscillatory motion and wave functions, as well as anyone needing to convert complex numbers into trigonometric forms.
anengstudent
If V = 5 + 12*j then write v(t) in the form v(t) = A*cos(w*t) + B*sin(w*t)
w = 10000 rad/s
N/A
I can easily put it into the form v(t) = C*cos(w*t + phi) and I can probably get the above form using a trig identity (haven't tried yet).
However, apparently it should be easily solvable by looking at it graphically.
I look at the case when t=0, then v(t) = C*cos(phi), the projection on the x-axis = 5.
Since x = cos(t) and y = sin(t) on the unit circle, then I figured v(t) = 5*cos(w*t) + 12*sin(w*t)
That works for t=0, but the actual answer is 5*cos(w*t) - 12*sin(w*t) (I found this by plotting it and 13*cos(w*t + arctan(12/5), they matched)
I seem to be on the right track but I don't understand the actual answer. The only resource I've found on the net puts +cos(t) on the positive x-axis but +sin(t) on the negative y axis... ?
I just don't understand and no one can help because it's an assignment question. I've got the mark now though because I know the answer, but I don't understand how to get it exactly.
Consider the trig identity for the cosine of the sum of two angles:
[tex]cos(\alpha + \beta) = cos(\alpha) cos(\beta) - sin(\alpha) sin(\beta)[/tex]
and work from your A*cos(ωt + φ) form.
37K
  • · Replies 29 ·
