| New Reply |
radiation device |
Share Thread |
| Jun2-11, 06:11 AM | #1 |
radiation device
Is there a hand-held device measures the percentage of radiation in the human body?
| Jun2-11, 07:47 AM | #2 |
Do you mean what % of background radiation is coming from a person?
| Jun2-11, 10:17 PM | #3 |
Your question is too vague. Do you understand what radiation exactly is and how it is created? If not, we can help you with that and then with your question.
| Jun3-11, 11:31 AM | #4 |
radiation device
Google "whole body counter".
| Jun4-11, 02:01 AM | #5 |
I do not have sufficient knowledge I heard about ( dosimeter ), this device WBC looks large, does not measure all the radiation, I thought that the topic was simpler than that.
Why there is no tables for the minimum and the maximum of what the body can bear and thus the person measuring the body |
| Jun4-11, 03:18 AM | #6 |
| Jun21-11, 07:26 AM | #7 |
Hi there,
I fully support what Drakkith said. Furhtermore, there are some kind of tables for the maximum radiation the body can bear. Anyway, estimation of what should not be over. The topic is quite complex since the danger comes from the different types of radiation, whether the radiation is external or internal, and each and every individual. This means that not everyone reacts the same way to radiation. Look at it the same way as with tobacco. It is impossible to say which cigarette will give you cancer. With some people it might be the first one, while others can smoke all their life without a problem. The same applies to radiation. |
| Jun21-11, 02:37 PM | #8 |
Whole Body Counters (WBC) are designed to measure all the ingested, inhaled, or injected radioactivity in the body to very high accuracy, for even very minute quantities. It will not detect alphas, unless accompanied by gammas. The detector is usually a lage (8" by 8" or larger) sodium iodide, and it is in a radiation clean room surrounded by pre-WW-II 6" thick steel walls for shielding. Patients are usually required to remove their clothing and wear special clean suits, and sit near the detector for 10 to 15 minutes.
Hand held counters cannot duplicate the sensitivity of whole body counters. The best hand held units are usually 3" by 3" sodium iodide or equivalent detectors. However, the hand held unit cannot easily discriminate between radioactivity on the clothing, on the body, or in the body. In both cases, a pulse height analyzer is required to identify radioactive isotopes. Bob S |
| Jun23-11, 03:22 PM | #9 |
Hmmm.. well anyone who works at a nuclear power plant must enter a whole body counter before he/she leaves work to ensure that he/she is not leaving with any contamination. The counter is designed to measure both internal and external contamination though. I guess if you cleaned up/stripped down and went into one of those you'd get a pretty accurate internal count.
By the way, what is the purpose of the thick steel plating? Can't the detector simply zero itself against the background count? |
| Jun23-11, 07:38 PM | #10 |
This pdf describes a typical vault-type whole body counter.
http://www.ornl.gov/info/reports/1988/3445602689160.pdf The thick steel vault shielding is made from low activation World War II steel armor shielding, and reduces the background counting rate to a very small % of natural (post nuclear weapon testing) background. Bob S |
| Jun23-11, 07:56 PM | #11 |
| Jun23-11, 10:28 PM | #12 |
Read http://www.sprawls.org/ppmi2/STATS/ Bob S |
| Jun24-11, 08:27 AM | #13 |
This site has a good explanation. http://www.rss.usda.gov/publications/mdatb.htm |
| New Reply |
Similar Threads for: radiation device
| Radiation protection/ effects of radiation | Nuclear Engineering | 15 | ||
| Is op amp or any amplifier circuit/device a over-unity device? | Electrical Engineering | 6 | ||
| Estimation of diffuse and direct radiation starting from the global radiation | General Physics | 1 | ||
| Emitted radiation and absorbed solar radiation | Astrophysics | 1 | ||
| Pelter Junction/Themoelectric device/Pelter Device Project | General Physics | 2 | ||
