Can Water Vaporize Without Affecting Other Components?”
  • Context: Undergrad
  • Thread starter Thread starter linques
    Components Water
The discussion revolves around the possibility of vaporizing water in a mixture (such as sugar or salt water) without simultaneously affecting the other components. Participants explore various methods of achieving this, including rapid temperature changes and pressure reduction, while questioning the underlying principles of evaporation and energy transfer.
  • One participant questions whether it is possible to vaporize water without affecting the other components in a mixture, suggesting that energy input is necessary for all components.
  • Another participant asserts that it is impossible to heat only the water without also heating the other materials.
  • A different approach is proposed involving reducing pressure to allow water to boil away, leaving the sugar behind.
  • Participants discuss the effect of blowing air across the mixture to increase evaporation rates, questioning whether this would also affect the other materials.
  • Concerns are raised about the homogeneity of the mixture and whether energy transfer during evaporation affects all components equally.
  • One participant explains that evaporation involves energy transfer between liquid molecules rather than from the air to the liquid.
  • Questions are posed about the nature of molecular bonds in solutions and whether energy transfer can occur selectively among different types of molecules.
  • Clarifications are made regarding the nature of solutes in a solvent and how they interact during evaporation.
Participants express differing views on the mechanisms of evaporation and energy transfer, with no consensus reached on the feasibility of vaporizing water without affecting other components in the mixture.
Participants highlight the complexity of interactions in solutions, including the roles of adhesive and cohesive forces, and the conditions under which evaporation occurs. There are unresolved questions regarding the specifics of energy transfer and molecular interactions in mixtures.
linques
other components?
Hello,
Lets say I have a glass of water with sugar or salt.
Is it possible to somehow turn the water into a vapor without inputing energy into the other materials in the mixture?
A microwave affects only water molecules, but when you raise their temperature- then obviously the heat treansfers into the the rest of the food.
I thought, that maybe if I somehow raise the tempeature rapidly the water will vaporize before any heat transferrence could occur... or is it just hogwash, since the energy to break molecuar bonds between the water and the material it is released from is constant and need to affect both the water and the other molecules?
Thank you very much.
Science news on Phys.org
There is no way to heat ONLY the water and avoid heating the other materials for the reason you said already.
Take a bottle of sugar water at room temp. and cap it and then reduce the pressure. Reduce the pressure enough and the water will boil away leaving the sugar behind.
Or don't raise the temp at all. Blow air across it, increasing evaporation rate.
Oh, I thought the OP already knew about that and was asking for another way lol. I think I got caught up on the heating part.
Thank you,
Lol, actualy I did know that though kinda forgot about it...
And it also did help me, though indeed I too was caught up with the heating in my original question...
But that would affect not only the water molecules? Wouldn't it?
Depends on what else would evaporate. Salt would not. Sugar would not.
If you leave a plate of these solutions out on a counter, the water will evaporate, leaving the precipitates behind.
Hmm...
(Im a bit ashamed for asking such rudimentary questions...:P)
But isn't evaporation is about transferring energy from the air to the substance?
Thus heating salt as well?...
linques said:
Hmm...
No the energy transfer is not from the air to iquid but between individual molecules of the liquid. Molecules keep colliding with each other. Sometimes at the surface, some molecule collisions give a lot of energy to some particular particles which, if moving in the right direction, can escape the forces that are holding the liquid together. So the total energy of the liquid decreases as a result of evaporation. This is why sweat helps to cool your body.
Sorry, should have explained myself better.
I meant that the mixture as a whole is pretty homogenous, so all of the water molecules are equaly binded with the molecules from the other material.
Thus processes that affect the water also will affect the other material just as much.
So the particles on the surface with enough energy to break bonds will be a) of both kinds, b)tied to the water molecules which escape.
Now I come to think about this...
1) I'm not sure that salt per se is actually tied to water, but rather is engulfed by its molecules... but I do know salt water is used as an air dessicant, so evaporation must differ than in regular water...
2) Sure it's the high energized particles that escapes, but isn't the initial energy from the air transfers to the entire fluid (surface), even if only one type of particles utilizes it for `freedom`?
3) Umm... Is breakage of molecular bonds possible when only one side has the energy required? Shouldn't some energy transsfer the other molecules?..
thank you.
thank you.
They don't bind to water in that sense. When in water, salt and sugar are in solution.
http://en.wikipedia.org/wiki/Solution#Solid
Regardless, they will not evaporate; they do not normally have a gaseous state.
Since the dissolved salt is already at room temperature, the only heat transfer from it is a small, but transient heat transfer out of it at the surface caused by the evaporation of the water around it. But once it reaches an equilibrium temp, that heat transfer stops while the evaporation continues.
This
doesn't follow from this.
linques said:
I meant that the mixture as a whole is pretty homogenous...
Homogeneity is condition where the concentration of solute is the same everywhere in the solvent.
Also molecules aren't equally bonded with each other. For a solute to dissolve in a solvent, the adhesive forces must be more than the cohesive forces i.e. the solute-solvent attraction should be greater than solute-solute or solvent-solvent attraction.
Yes right, but the ones that escape are only the solvent molecules and not the solute because they are not held by the forces of attraction from other solvent molecules. Although the solute apples and attractive force, solvent is in much larger quantity and hence net attraction on solvent molecules is less.
As I already said, the energy transfer is between the molecules in the solution itself and not air.
Sorry couldn't understand what you said.
  • · Replies 16 ·
14K
  • · Replies 21 ·
