Does there exists a matrix who's product is itself?
  • Context: Undergrad
  • Thread starter Thread starter mscudder3
    Matrix Product
The discussion revolves around the existence of matrices that satisfy the property \(AA = A\), specifically within the context of \( \mathbb{R}^2 \). Participants explore various types of matrices, including orthogonal projections and reflections, and engage in a dialogue about constructing such matrices and understanding their properties.
  • Some participants suggest that the identity matrix satisfies the property \(AA = A\), while others recall the existence of matrices with all nonzero entries that may also satisfy this condition.
  • There is a proposal to investigate orthogonal projections or reflections as potential candidates for matrices that satisfy \(AA = A\).
  • One participant expresses uncertainty about constructing such a matrix and requests guidance on how to do so.
  • A specific construction of a projection matrix is discussed, where a matrix of the form \(\begin{pmatrix} \frac{1}{2} & \frac{1}{2} \\ \frac{1}{2} & \frac{1}{2} \end{pmatrix}\) is identified as satisfying \(AA = A\).
  • Another participant questions the derivation of the projection matrix and discusses the implications of projecting onto different lines through the origin, noting that various lines yield matrices that also satisfy \(AA = A\).
  • There is a mention of using unit vectors to construct matrices that satisfy the property, with a suggestion that any unit column vector can be used in this context.
Participants exhibit a mix of agreement and uncertainty regarding the construction of matrices that satisfy \(AA = A\). While some examples are provided, there is no consensus on the generality of the findings or the methods used to derive them.
Participants express varying levels of familiarity with the theoretical underpinnings of linear algebra, indicating that some may struggle with the general theory despite being able to apply specific examples. There are also unresolved questions about the mathematical derivation of certain properties and the implications of projecting onto different lines.
mscudder3
To simplify this inquiry let us deal with R2. I know that if you have the identity matrix (let that be A), then AA=A. However, I recall the existence of a matrix with all nonzero entries that had the same property. Thinking of rotations, I cannot think of one, (since rotating by 0, or 2pi is equivalently the identity matrix). I'm sure that there must exist some type of orthogonal projection or reflection, but I'm unsure.
Thanks in advance!
So instead of wondering, why not actually try an orthogonal projection or a reflection?
(aside -- you could always reduce the problem to an ordinary algebra problem with real numbers)
... I was wondering as in I cannot recall or figure it out.
Reducing it to algebra in terms of some a1 a2 a3 a4 (forming a 2x2), all that resolves is trivial solutions.
Would it be that difficult to show me one?
No, but you would learn more if you construct one yourself.
Now, take the line y=x in [itex]\mathbb{R}^2[/itex]. Can you construct the matrix of the orthogonal projection on that line?
Let A=[a1 a2 ; a3 a4]. since y=x the vector x=(x1, x2)^t=(1, 1)^t
From the definition of a projection= [u1^2, u1*u2 ; u1*u2 u2^2]
I can see that if a1=a2=a3=a4=1/2 then,AA=A. However, I'm not quite sure on how/why?
Edit:
From Ax=b let x=(1 1)^t and A=projection and solve for u1 and u2 (which yields 1/2 for each entry). Then by the def of projection, b must be equal to x?
mscudder3 said:
From the definition of a projection= [x1^2, x1*x2 ; x1*x2 x2^2]
Umm, I'm not sure where you got that formula... But the matrix
[tex]\left(\begin{array}{cc} \frac{1}{2} & \frac{1}{2}\\ \frac{1}{2} & \frac{1}{2}\\ \end{array}\right)[/tex]
Certainly satisfies A2=A. So you've found your matrix!
Ya thanks! Now that you have me thinking I'd like to understand exactly how I arrived at this solution. I got that equation (or matrix) from my text: Linear Algebra 4e by Bretscher. Book is VERY heavy on application, thus my struggle with the general theory.
It's actually very easy once you know it! :smile:
Just take the standard basis of [itex]\mathbb{R}^2[/itex], that is: (1,0) and (0,1). The key point is checking where they are projected. A little bit of drawing (or calculating) gives us that (1,0) is being sent to (1/2,1/2) and (0,1) is being sent to (1/2,1/2). Thus (1/2,1/2) and (1/2,1/2) make up the columns of our matrix.
Note that there was nothing special about projecting on the line y=x. You can pick any line through the origin, they will all give you a matrix such that A2=A.
For example, let me project on y=-x. Then (1,0) is being sent to (1/2,-1/2) and (0,1) is being sent to (-1/2,1/2). Thus the matrix becomes
[tex]\left(\begin{array}{cc}\frac{1}{2} & -\frac{1}{2}\\ -\frac{1}{2} & \frac{1}{2}\\ \end{array}\right)[/tex]
As you can see this matrix also satisfies A2=A.
Great! Thanks so much.
To briefly expand on your explanation, when you say it sends the basis (by the linear transform), how exactly do these numbers come about mathematically. I know I may be overlooking something, but I want to be complete.
From what I see, the length of the basis is clearly 1 (hence unit vector). Thus if that is projected onto y=x the new basis would be 1/sqrt(2), not 1/2.
Hello mscudder3,
Take any unit column vector a (i.e., nx1 matrix with sum of square of moduli of its elements being 1, where n is the number of your choice). Then the matrix m=[tex]aa^\dagger[/tex] will satisfy [tex]m^2=m.[/tex]
  • · Replies 33 ·
  • · Replies 20 ·
  • · Replies 24 ·
  • · Replies 0 ·
