Ray Tracing and Lens Formula for Image Location
The problem involves ray tracing and the lens formula to determine the location of an image formed by a concave lens. The original poster presents a scenario with an object placed 15 cm in front of the lens, which has a focal length of 10 cm.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to use ray tracing to find the image location and questions the correctness of their calculations using the lens formula. Some participants suggest considering the sign convention for concave lenses and adjusting the focal length accordingly.
Participants are exploring the implications of sign conventions and the lens formula for concave lenses. There is acknowledgment of a potential misunderstanding regarding the calculations, but some participants confirm the results derived from the equations. The discussion appears to be productive, with guidance offered on the correct application of the lens formula.
There is a mention of confusion regarding the application of the lens formula and the sign convention for concave lenses, which may affect the calculations. The original poster expresses uncertainty about the results obtained from their attempts.
anotherperson
An object is locted 15cm infront of a convae lends with a focal length of 10cm. use ray tracing to determine the location of the image. try to draw to scale
i)is the image upright or inverted?
ii)is the image real or virtual?
iii)use your ray-tracing diagram to determine the distance from the lens to the image and label your diagram with this value
iv)now calculate this lens to image distance using the thing lens formula
v) determine the linear magnification of the image relative to the object
1/p+1/q=1/f
m=-q/p
the image will be upright and virtual. and i was able to do the ray tracing diagram
for part iii) I am unsure which equation to use as if i use the lens formula i get the wrong answer,
1/15+1/q=1/10
and hense the wrong answer for part iv)
i'm able to work out v if i have the answer for iv. as m=-q/p which will be m=-answer/15
remember that for concave lenses, focal length is negative. try (-1/10cm) instead of (1/10cm).
Use proper sign convention.
What change you have to make in the lens formula when you are using concave and convex lens?
i still get the wrong answer if i do
1/15+1/q=-1/10
What is your answer ?
ohhh no it is right
-6 meaning its 6cm away and then the next part it is also 6cm making my magnification 0.4. is that correct?
my equations show the same result, so i say yes.
thanks!
  • · Replies 16 ·
