Physics: Potential Energy Beyond Earth's Surface
The discussion revolves around the concept of gravitational potential energy (PE) beyond the surface of the Earth, particularly comparing the classical formula PE = mgh for near-surface conditions with the more general formula PE = -GMm/r applicable at greater distances. Participants explore the implications of changing gravitational force and the definitions of potential energy in different contexts.
  • One participant notes that the formula PE = mgh is valid near the Earth's surface due to the constant gravitational force, while questioning its applicability at greater distances where gravitational force changes.
  • Another participant confirms that the general formula for gravitational potential energy, derived from integrating the gravitational force, is U = -GMm/r, which accounts for the changing force with distance.
  • Concerns are raised about the validity of comparing the work done to move an object from infinity to a point x versus from x to the ground, with some arguing that the latter leads to an infinite potential energy at the ground.
  • Participants discuss the implications of singularities in gravitational force at r=0, suggesting that defining potential energy from this point is problematic.
  • There is a debate about the interpretation of mgh as the energy an object has when it reaches the ground, with clarifications that it only applies under specific conditions (e.g., falling from rest without external forces).
  • One participant explains how mgh can be derived from the integral definition of potential energy under the assumption that height is much smaller than the Earth's radius.
  • Another participant introduces the concept of gravitational potential energy from an infinite plane and contrasts it with finite sources of gravity, noting the differences in reference points for potential energy.
Participants express differing views on the relationship between the two formulas for potential energy, with some asserting they are equivalent under certain conditions while others highlight significant differences. The discussion remains unresolved regarding the implications of these differences and the definitions of potential energy.
Participants acknowledge limitations in their arguments, including assumptions about the distance from the Earth and the nature of gravitational force at different points. The discussion also reflects on the mathematical steps involved in deriving potential energy formulas, which may not be fully resolved.
nhmllr
Sorry to post two PE posts in the same day...
Anyway, I understand how near the surface of the earth, PE = mgh,
becuase E = F*d, mg = F, h = d.
When the object hits the ground after height h, it has had the force mg work on it for h
But "g" changes with the distance from earth
Fgravity = mMG/r^2
Fgravity * h = mMG/r
(M = Earth's mass)
So should PE = mMG/r (when not near the surface, such as in orbits) because that's how I've seen it been written.
Should it be something different because the force working on it increases as it falls?
Thanks
It is exactly as you described. The equation U = -mgh is an approximation for objects near the surface of the Earth. The equation you described comes from
[tex]U = \int^{x}_{\infty}\frac{GMm}{r^{2}}dr[/tex]
[tex]U = -\frac{GMm}{x}[/tex]
which takes into account the changing gravitational force. In physics, it is often convinient to define potential energy as the amount of work needed to bring an object from infinity to the current location. This formula follows from that convention.
Hm... that's interesting how you got it from the sums of all of the forces through a distance...
But how do you know that the work needed to get it from infinity to x is the same as from x to 0? In fact, when you plug 0 and x into the integral, you get infinity!
They are not the same. The force at the point 0 contains a singularity, it makes no real sense to define potentials from 0.
What I mean is, you defined PE as the work done to get the object from infinity to x. mgh means that PE is work that will be done when you get it from x to 0. However, that will be infinite. So I'm wondering how the work to done to get it from infinity to x = work done to get it from x to 0.
The work done to get it from infinity to X DOES NOT EQUAL the work done to get it from X to 0.
An object at infinity has zero gravitational potential energy (just set x=infinity in Yuqing's equation above). And at some point X close to the surface of Earth, the GPE is finite and non-zero. To the work done in moving the object from infinity to the new location X is FINITE, not infinite.
Now, the gravitational force at r=0 is NOT given by F=GMm/r^2. In fact, there's a delta function at r=0; all the gravitational flux emanates from r=0. When integrating to find the amount of work required in moving an object from the center of the Earth to location X, the limits of integration are from some infinitesimal distance from the center of the Earth--which we can call epsilon-- all the way up to the location X. Again, when you follow Yuqing's equation, plugging in these limits (epsilon and X), you'll get a FINITE amount of work done.
What I don't understand is that mgh is taught that it's the energy that the object will have when it reaches the ground. -mMG/r has a completely different definition, yet it shares the same name! How are they the same?
Well, mgh actually follows from the integral definition by an approximation.
Let us consider the difference in potential between two points of distance r and r+h.
We have
[tex]\frac{-GMm}{r+h} - \frac{-GMm}{r} = \frac{GMmh}{r(r+h)}[/tex]
now let us take r as the radius of the Earth and restrict h << r (as is required by mgh).
Since h << r we have r + h [tex]r+h \approx r[/tex] where our equation becomes
[tex]\frac{GMmh}{r^{2}}[/tex]
the term [tex]\frac{GM}{r^{2}}[/tex] if you recall is precisely g. Thus the expression reduces to mgh.
If you recall, "mgh" is NOT the energy that the object will have when it hits the ground unless the object falls from rest (and we neglect frictional forces, drag, and other outside forces). The change in potential energy equals the change in kinetic energy. If the object falls from rest (kinetic energy is initially zero), then that gravitational potential energy is converted into kinetic energy. The first sentence of this paragraph and this last statement may seem like they're equivalent, but they're not.
mgh is an approximation for relatively short distances from the earth.
mgh would be the formula for an infinite plane with enough mass per unit area to produce an acceleration of g on any mass. The force from such a plane is constant regardless of distance from the plane, and the maximum potential energy from such a plane mgh as h -> ∞ is infinite. For a infinite plane the usual "reference" distance is 0 distance from the plane.
For a finite size source of gravity the maximum potential is finite, so a distance of ∞ is the usual "reference" distance.
Although not common for gravity, an infinite line source for a field is sometimes used in electrical field problems. In this case for gravity from an infinite line, the potential energy would be m g ln(h), where h is distance from the line. In this case some non-zero but finite distance is normally used as the reference points (note that ln(1) = 0).
We have
I agree, Yuqing.
We have
That's a great explanation. I understand it now! Thanks everybody for your patience
  • · Replies 46 ·
  • · Replies 29 ·
  • · Replies 54 ·
