Few chemistry tasks that I don't understand at all
  • Thread starter Thread starter Vichy
    Chemistry
This discussion focuses on several chemistry tasks involving reactions and calculations with barium chloride (BaCl2), iron (III) sulfate, sulfuric acid (H2SO4), and hydrochloric acid (HCl). Key tasks include calculating the mass of precipitate formed from a BaCl2 and iron (III) sulfate reaction, determining the weight percentage of copper in a copper-zinc solution after reacting with H2SO4, and finding the amount of iron that reacts with HCl. The user emphasizes the need for starting with reaction equations to solve these problems effectively.
  • Understanding of stoichiometry in chemical reactions
  • Familiarity with molarity and density calculations
  • Knowledge of precipitation reactions and solubility rules
  • Basic skills in balancing chemical equations
  • Study stoichiometry and its applications in chemical reactions
  • Learn how to calculate molarity and density in solution chemistry
  • Research precipitation reactions and how to predict products
  • Practice balancing chemical equations with various reactants
Chemistry students, educators, and anyone looking to improve their problem-solving skills in chemical reactions and stoichiometry.
Vichy
1. Here are few chemistry tasks,I need your help!
2.
4.120g 15% BaCl2 solution is added to 800ml 0,2mol/L Iron (III) sulphate solution.How many g of precipitate formed?Which and how much of material did not react?
5. 5g of solution,which consists of copper and zinc,is affected by solution of H2SO4. 0,05 mol of gas formed.Calculate W% of copper in the solution.
6.How many g of Fe(sawdust of Fe) will react when added to 50ml 20% HCl solution which has density of 1,1g/cm3 ?
7.What density of 20% HCl(density-1,1g/cm3) solution is needed to dissolve 30g Iron (III) oxide,which has 20% of addition?
8.How many g of salt will form,if 20g of Fe which has 10% of addition,will be affected by solution of H2SO4?
3. As I mentioned I can't understand this at all so I didn't make any attempts on solving these tasks.If you see any grammar mistakes-I'm sorry for that,English isn't my native language.
Each time you need to start with reaction equation(s).
11K
18K
  • · Replies 19 ·
11K
