Determining number of possible move sequences in Connect-4
  • Context: Undergrad
  • Thread starter Thread starter NickBach
    Sequences
The discussion focuses on calculating the number of possible move sequences in the game Connect 4, which consists of 7 columns with a maximum of 6 discs each. The formula established for determining the total sequences of moves, assuming all 42 spots are filled without a winner, is given by the multinomial coefficient 42! / (6!)^7. This approach effectively accounts for the permutations of disc placements across the columns. The conversation also highlights the need for efficient algorithms to manage move generation in programming implementations of the game.
  • Understanding of combinatorial mathematics, specifically multinomial coefficients
  • Familiarity with the rules and mechanics of Connect 4
  • Basic programming skills for implementing game logic
  • Knowledge of factorial calculations and their applications in permutations
  • Research the implementation of multinomial coefficients in programming languages
  • Explore algorithms for optimizing move generation in Connect 4
  • Learn about game tree algorithms, such as Minimax, for decision-making in two-player games
  • Investigate performance profiling techniques to analyze and improve game responsiveness
Game developers, mathematicians interested in combinatorial game theory, and programmers working on AI for Connect 4 or similar two-player games will benefit from this discussion.
NickBach
There's a game that's been around for a long time called Connect 4. It is a 2-player game consisting of 7 columns that can hold 6 discs each. The players alternate dropping a disc of their color into one of the 7 columns until a player has 4 in a row, either horizontally, vertically, or in a diagonol (or until all 42 spots are filled in without a 4-in-a-row sequence resulting that is a tie). I'm trying to determine how many different possible sequences of moves can be made to fill in the remaining spots (assuming a tie will result) at any point during the game. For example, assume the 7 colums already have 2, 1, 6, 4, 5, 0, 2 discs in them (a total of 20), how many ways can the last 22 positions be filled in? Remember, all 22 remaining spots cannot be selected for the next move, only the next one up in each column that currently has less than 6 discs in them. And also, if player A drops 2 discs into the 1st column while player B drops 1 disc into the 4th and then the 5th columns, it should be considered a different sequence than if player B first dropped a disc into the 5th column followed by a disc into the 4th column on this second turn.
Thanks,
Nick
Thanks,
Nick
Hi Nick,
If I understand you correctly, the players are to continue taking turns until all 42 spots are filled, is that right? If so, I think there are
[tex]\frac{42!}{(6!)^7}[/tex]
possible games.
To see this, lay out 42 disks in a row and mark each disk with a number from 1 to 7, using each number exactly 6 times. This can be done in
[tex]\binom{42}{6 \; 6 \; 6 \; 6 \; 6 \; 6 \; 6}[/tex]
ways (a multinomial coefficient). http://en.wikipedia.org/wiki/Multinomial_coefficient
Have the players take turns picking up a disk, working from left to right, color it with the appropriate color for the player, and drop it in the column matching the mark on the disk.
Finally,
[tex]\binom{42}{6 \; 6 \; 6 \; 6 \; 6 \; 6 \; 6}= \frac{42!}{(6!)^7}[/tex]
awkward,
Sounds so simple the way you explain it. Thanks for the reply (and the informative link). I'm trying to write a program to play the game and sometimes the computer seems to be hung while thinking about its move. I want to put in a status of how far along it is in generating its move, but was struggling to come up with the formula to use.
Thanks,
Nick
10K
