How Does Affine Geometry Define the Join of Subspaces?
  • Context: Graduate
  • Thread starter Thread starter mma
    Geometry
The discussion centers on the definition of the join of subspaces in affine geometry, specifically the notation A∧B as the smallest flat in the affine space \mathcal{A}(V) containing both subspaces A and B. The participants highlight a flaw in the original assertion that the associated subspace of A∧B can be represented as \operatorname{span}(S_1\cup S_2) when A and B are skew lines. The corrected formulation states that A∧B should be expressed as A∧B = a + (S_1 + S_2 + \operatorname{span}\{b-a\}), which accurately reflects the geometric relationship.
  • Understanding of affine geometry concepts
  • Familiarity with Zorn's lemma
  • Knowledge of vector spaces and subspaces
  • Basic grasp of linear algebra operations
  • Study the implications of Zorn's lemma in affine geometry
  • Explore the properties of upper semilattices in mathematical structures
  • Learn about the geometric interpretation of skew lines in \mathbb{R}^3
  • Investigate the relationship between affine spaces and vector spaces
Mathematicians, geometry enthusiasts, and students of linear algebra seeking to deepen their understanding of affine geometry and its applications in higher-dimensional spaces.
mma
http://planetmath.org/encyclopedia/AffineGeometry.html" writes:
In addition, we define [itex]A\vee B[/itex] to be the smallest flat in [itex]\mathcal{A}(V)[/itex] that contains both [itex]A[/itex] and [itex]B[/itex]. By Zorn's lemma, [itex]A\vee B[/itex] exists. Since [itex]A\vee B[/itex] is also unique, [itex]\vee[/itex] is well-defined. This turns [itex]\mathcal{A}(V)[/itex] into an upper semilattice. If [itex]S_1[/itex] is the associated subspace of [itex]A[/itex] and [itex]S_2[/itex] is the associated subspace of [itex]B[/itex], then [itex]\operatorname{span}(S_1\cup S_2)[/itex] is the associated subspace of [itex]A\vee B[/itex].
As far as I see, this is wrong. For example, let be [itex]V=\mathbb{R}^3[/itex], [itex]S_1=\{(x,0,0):x\in \mathbb{R}\}[/itex] , [itex]S_2=\{(0,y,0):y\in \mathbb{R}\}[/itex], [itex]A=(0,0,1)+S_1[/itex] and [itex]B=S_2[/itex]. Then [itex]A[/itex] and [itex]B[/itex] are skew lines, that is, there isn't any plane containing both line. While any flat with associated subspace [itex]\operatorname{span}(S_1\cup S_2)[/itex] is a plane.
Am I right? If yes, then what would be the correct statement here?
Hi mma! :smile:
Yes, as far as I can see, the last sentence is not correct. It can be corrected as follows: if A=a+S1 and B=b+S2, then
[tex]A\vee B=a+(S_1+S_2+span\{b-a\})[/tex]
Yes, this seems better, thank you!
  • · Replies 42 ·
12K
  • · Replies 93 ·
17K
  • · Replies 102 ·
12K
  • · Replies 100 ·
13K
  • · Replies 39 ·
14K
  • · Replies 64 ·
16K
  • · Replies 175 ·
28K
  • · Replies 61 ·
11K
