Power and energy from continuous to discrete
The discussion focuses on the equivalence of energy and power definitions for continuous and discrete signals, specifically using the sampled signal x[n] and its Fourier transform X_s(f). The energy E_x and power P_x are defined for continuous signals as E_x = ∫ |x(t)|² dt and P_x = lim_{T→∞} (1/T) ∫ |x(t)|² dt, while for discrete signals, they are represented as E_x = T_s Σ |x[n]|² and P_x = lim_{N→∞} (1/(2N+1)) Σ |x[n]|². The discussion confirms the equivalence of these definitions under specific conditions, particularly when T_s = 1/(2W), and explores the implications of using the Fast Fourier Transform (FFT) for finite sequences.
  • Understanding of continuous and discrete signal processing
  • Familiarity with Fourier Transform and Discrete Fourier Transform (DFT)
  • Knowledge of energy and power calculations in signal theory
  • Basic concepts of sampling theory and the Nyquist criterion
  • Study the implications of Parseval's theorem in signal processing
  • Learn about the Fast Fourier Transform (FFT) and its applications in analyzing discrete signals
  • Explore the relationship between energy spectral density and signal power
  • Investigate the effects of different sampling rates on signal fidelity and reconstruction
Signal processing engineers, electrical engineers, and students studying communications or control systems will benefit from this discussion, particularly those interested in the mathematical foundations of signal energy and power analysis.
jashua
The energy and the power contents of a signal x(t), denoted by [itex]E_x[/itex] and [itex]P_x[/itex], respectively, are defined as
[itex](1) E_x = \int ^{\infty}_{-\infty} |x(t)|^2 dt[/itex]
[itex](2) P_x = lim_{T\rightarrow \infty} \frac{1}{T} \int ^{T/2}_{-T/2} |x(t)|^2 dt[/itex]
Let us use the discrete time (sampled) signal, with sampling period [itex]T_s[/itex]. Then, the first problem is to show that these definitions are equivalent to the following ones:
[itex](3) E_x = T_s \sum ^{\infty}_{n=-\infty} |x[n]|^2[/itex]
[itex](4) P_x = lim_{N\rightarrow \infty} \frac{1}{2N+1} \sum ^{N}_{n=-N} |x[n]|^2[/itex]
Now, if we use the FFT, that is, if the length of the sequence is finite and the sequence is repeated. Then, the next problem is to show that these definitions (#1 and #2) are equivalent to the following ones (i think only one period should be considered for [itex]E_x[/itex]):
[itex](5) E_x = T_s \sum ^{N-1}_{n=0} |x[n]|^2[/itex]
[itex](6) P_x = \frac{1}{N} \sum ^{N-1}_{n=0} |x[n]|^2[/itex]
My work to solve these questions are as follows:
Let us define the sampled waveform [itex]x_s(t)[/itex]:
[itex]x_s(t) = x(t) \sum ^{\infty}_{n=-\infty}\delta (t-nTs).[/itex]
[itex]= \sum ^{\infty}_{n=-\infty}x(nT_s)\delta (t-nTs).[/itex]
[itex]= \sum ^{\infty}_{n=-\infty}x[n]\delta (t-nTs).[/itex]
Then, the Fourier transform of [itex]x_s(t)[/itex], [itex]X_s(f)[/itex] is
[itex]X_s(f) = \sum ^{\infty}_{n=-\infty}x[n]e^{-j2\pi f n T_s}.[/itex]
which is nothing but the DFT of the discrete time sequence x[n].
On the other hand, we can express [itex]X_s(f)[/itex] in terms of [itex]X(f)[/itex] (using Poissson's sum formula) as follows:
[itex]X_s(f) = X(f) \ast \frac{1}{T_s} \sum ^{\infty}_{n=-\infty}\delta (n-\frac{n}{T_s}).[/itex]
[itex]= \frac{1}{T_s} \sum ^{\infty}_{n=-\infty}X(f-\frac{n}{T_s}).[/itex]
where [itex]\ast[/itex] is the convolution operator.
Hence, we have
[itex]X_s(f)=\frac{1}{T_s}X(f)[/itex], [itex]|f|<W[/itex].
Then, the energy spectral density is found to be [itex]\epsilon_x (f) = |X(f)|^2 = {T_s}^2 |X_s(f)|^2[/itex]. Now we can find [itex]E_x[/itex] using the following formula:
[itex]E_x = \int ^{\infty}_{-\infty} \epsilon_x (f) df[/itex]
[itex]= {T_s}^2 \int ^{W}_{-W} |X_s(f)|^2 df[/itex]
[itex]= {T_s}^2 \int ^{W}_{-W} \sum ^{\infty}_{n=-\infty}x[n]e^{-j2\pi f n T_s} \sum ^{\infty}_{m=-\infty}x[m]^\ast e^{j2\pi f m T_s}df[/itex]
[itex]= {T_s}^2 \sum ^{\infty}_{n=-\infty}x[n] \sum ^{\infty}_{m=-\infty}x[m]^\ast \int ^{W}_{-W} e^{j2\pi f (m-n) T_s}df[/itex]
[itex]= {T_s}^2 \sum ^{\infty}_{n=-\infty}x[n] \sum ^{\infty}_{m=-\infty}x[m]^\ast 2W sinc(2WT_s(m-n))[/itex]
[itex]= {T_s}^2 2W \sum ^{\infty}_{n=-\infty} |x[n]|^2[/itex]
where [itex]x[m]^\ast[/itex] is the conjugate of [itex]x[m][/itex]. If [itex]T_s=\frac{1}{2W}[/itex], then we have shown the definitions #1 and #3 are equivalent.In order to show that the definitions #2 and #4 are equivalent, let [itex]T=(2N+1)T_s[/itex] such that
[itex]x_{s_T}(t)= \sum ^{N}_{n=-N}x[n]\delta (t-nTs)[/itex]
Then, we have,
[itex]lim_{T\rightarrow \infty}X_{s_T}(f) = lim_{N\rightarrow \infty} \frac{1}{T_s} \sum ^{N}_{n=-N}X(f-\frac{n}{T_s})[/itex]
And hence,
[itex]lim_{T\rightarrow \infty} X_{s_T}(f)=\frac{1}{T_s}X(f)[/itex], [itex]|f|<W[/itex].
Substituting [itex]X(f)=T_s X_{s_T}(f)[/itex] into the definition # 1 (after applying Parseval relation), we get
[itex]P_x = lim_{T\rightarrow \infty} \frac{1}{T} \int ^{T/2}_{-T/2} |x(t)|^2 dt[/itex]
[itex]= lim_{T\rightarrow \infty} \frac{1}{T} \int ^{\infty}_{-\infty}|x(t)|^2 dt[/itex]
[itex]= lim_{T\rightarrow \infty} \frac{1}{T} \int ^{\infty}_{-\infty}|X(f)|^2 df[/itex]
[itex]= lim_{T\rightarrow \infty} \frac{1}{T} {T_s}^2 \int ^{W}_{-W}|X_{s_T}(f)|^2 df[/itex]
Now substituting [itex]X_{s_T}(f)=\sum ^{N}_{n=-N}x[n]e^{-j2\pi f n T_s}[/itex], and [itex]T=(2N+1)T_s[/itex], we get
[itex]P_x = lim_{N\rightarrow \infty} \frac{1}{(2N+1)T_s} {T_s}^2 \int ^{W}_{-W} \sum ^{N}_{n=-N}x[n]e^{-j2\pi f n T_s} \sum ^{N}_{m=-N}x[m]^\ast e^{j2\pi f m T_s} df[/itex]
[itex]= lim_{N\rightarrow \infty} \frac{1}{(2N+1)T_s} {T_s}^2 2W \sum ^{N}_{n=-N} |x[n]|^2[/itex]
If [itex]T_s=\frac{1}{2W}[/itex], then,
[itex]P_x= lim_{N\rightarrow \infty} \frac{1}{2N+1} \sum ^{N}_{n=-N} |x[n]|^2[/itex]
Hence we have shown the definitions #2 and #4 are equivalent.
Am I correct up to this point?
I'm still trying to get some satisfactory solutions to show the relation between the definitions #1 and # 5 and the definitions #2 and # 6 and waiting for some help.
Let me give an answer to my question :)
As the sequence is repeated we can rewrite the definition # 4 as follows (assuming the period [itex]T=NT_s[/itex]):
[itex]P_x = lim_{M\rightarrow \infty} \frac{1}{MN} M \sum^{N-1}_{n=0} |x[n]|^2[/itex]
[itex]= \frac{1}{N}\sum^{N-1}_{n=0} |x[n]|^2[/itex]
Hence, the definitions #2 and #6 are equivalent.
Now, since the energy of a periodic sequence is calculated over one period (by its definition) only, we can rewrite the definition # 3 as follows:
[itex]E_x = T_s \sum^{N-1}_{n=0} |x[n]|^2[/itex].
However, can we obtain these results using the sampled waveform over one period directly?
  • · Replies 0 ·
9K
