How to deal with a probability conditioned on empty
  • Context: Graduate
  • Thread starter Thread starter sabbagh80
    Empty Probability
The discussion revolves around the interpretation of the probability Pr(A|Φ), where Φ represents an empty set. Participants explore the implications of conditioning on an empty set within the framework of probability theory, examining whether such a probability can be defined and what it might mean.
  • One participant questions whether Pr(A|Φ) is equal to 1, seeking clarification on the meaning of this probability.
  • Another participant argues that conditioning on an empty set does not yield a meaningful probability, as it cannot be assigned a probability measure within any probability space.
  • A different viewpoint suggests that while Pr(A|empty set) may not make sense in traditional terms, practical problems might require alternative definitions or provisions to handle such cases, using an example involving a uniform random variable.
  • One participant emphasizes that the original question about Pr(A|empty set) cannot be reinterpreted outside the established theory of probability, asserting that their previous answer suffices.
  • A participant inquires about the motivation behind the question, asking if it stems from curiosity or a specific application.
  • The original poster clarifies that the question arose from a different problem and is not directly related to a specific application.
Participants express differing views on the validity and interpretation of Pr(A|empty set). There is no consensus on whether such a probability can be meaningfully defined, indicating ongoing disagreement.
The discussion highlights limitations in defining probabilities conditioned on empty sets and the dependence on the framework of probability theory. There are unresolved assumptions regarding the applicability of traditional probability measures in these scenarios.
sabbagh80
Hi everyone,
The question:
[itex]Pr( A|\Phi )=?[/itex] where [itex]\Phi[/itex] means empty
Is it equal to 1 or not?
what is the meaning of this probability?
thanks.
A|empty set = empty set is an event in the empty "probability space", for which you can't assign a probability measure, so it isn't a probability space after all. So A|empty set isn't an event in any probability space, so Pr(A|empty set) doesn't make sense.
The axioms for a probability measure P on a sigma algebra X is that P(empty set) = 0, and P(X) = 1. But in this case X = empty set, so P(X) = 0, so such a measure cannot exist.
disregardthat said:
A|so Pr(A|empty set) doesn't make sense.
However, in practical problems you may need to dance around that obstacle.
For example, if W is a uniform random variable on [0,1] then you might want to define a function
F(z,x,y) = P(W > z | x < W and W < y)
This function wouldn't exist at values such as x = 4 and y = 3.
If you want to define F(z,x,y) there, you have to include an additional provision in its definition. The most common one would be to say:
F(z,x,y) = P(W > z | x < W and W < y) when the set defined by (x < W
and W < y) is not empty. F(z,x,y) = 0 otherwise.
This is not extending the theory of sample spaces. It is extending the definition of a function, rather like removing a discontinuity.
Sure, we can define what would otherwise be meaningless all day long. OP asked for the probability of A|empty set, and that cannot be interpreted in any other way than what the theory of probability of reference would yield for Pr(A|empty set). For that my answer is sufficient.
sabbagh80,
Are you asking the question merely out of curiosity or did you have a specific application in mind that must deal with it?
Stephen Tashi,
No, it is not related to an specific application. this question arose me when I was dealing with another problem and was not directly related to that problem.
  • · Replies 29 ·
  • · Replies 22 ·
