New Reply
Finding the instantaneous axis of rotation (dynamics - circular and linear motion)
Share Thread Thread Tools
Jun11-11, 02:03 AM   #1
Recognitions:
Gold Membership Gold Member
Shaft's AC movement is regulated by runways A and B. The angular velocity of the shaft is 3 rad/sec, counterclockwise. When angle psi = 40 degrees. Calculate:
A) The velocities of pistons A and B (Va, Vb)
B) The velocity of point C (Vc) - magnitude and direction towards the horizontal axis.
3. The attempt at a solution
My problem is finding P - the instantaneous axis of rotation. I picked this:
Picking it, I got the correct Va, the correct Vb, and the correct Vc. (I'm still working on the angle of Vc to the horizontal axis - so far it's not correct but maybe I'm doing something obviously wrong.)
And the solution manual picked that:
Are they both correct?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Jun11-11, 02:19 AM   #2
There is a very straightforward way to relate Vc to Va and Vb.
The book solutions are correct but they're complicated
Jun11-11, 02:34 AM   #3
Recognitions:
Homework Helper Homework Help
The instantaneous axis is the center of movement.
This means that all points of the body make a circular motion around this axis.
In your case you know the direction of the speed at 2 points.
Are they making a circular motion around your P?
Jun11-11, 02:37 AM   #4
Recognitions:
Well I just wanna know how come P is in the opposite direction to my P? It's pretty easy to solve this the way the manual did actually. You just find the distance from point B to P and the distance from point A to P and the distance from point C to P and do angular velocity times this distance and you get the answer. Finding the angle of C is a bit more tricky, but I first of all wanna know if I got the correct P because it gives me the same result as they....
Edit: Nevermind, I get it. It depends on the direction of the rotation! :)
Jun11-11, 02:40 AM   #5
Recognitions:
Quote by Femme_physics View Post
Hmm, I would have worded it differently.
I'd have said that any speed vector must be perpendicular....
Jun11-11, 02:48 AM   #6
Recognitions:
Fair enough, but if my P is where the solution manual says, then I get opposite results for Va and Vb to what the manual says I should get!
Jun11-11, 02:53 AM   #7
Recognitions:
Perhaps if you switched the letters A and B around?
You might say of course that you're not allowed to do that.
But then, if I look at the original problem, it seems to me that they did exactly that!
Jun11-11, 02:57 AM   #8
Recognitions:
*an embarrassing look*
Oh.
*slaps forehead*
Ouch.
I really gotta stop doing that...
Thanks ILS :) Problema el solva (I have no idea if what I wrote is lingually correct)......
Jun11-11, 03:28 AM   #9
Recognitions:
*slaps forehead*
Ouch.
What? The switching around of letters and similar stuff?
Or the slapping?
You can slap me if you want!
If it is or not, it sounds nice!
Jun11-11, 03:41 AM   #10
Recognitions:
Actually, still one problem. Finding the angle of Vc to the horizontal axis. I get 61.4 but the manual gets 59.21... I feel it's too much to chalk it up to "rounding errors".
Uploaded with ImageShack.us
Or the slapping?
Both!
Slap you? But why?!? I can't. I'm too gentle and soft. And you're too harmless. Well, maybe a little. *soft slap*... *little less of a soft slap*...
*slaps!*
*SLAPS!!*
*THUMPS!!!!*
*MONSTER THUMP!*
Woah, sorry, lost control
Told you I'm a fast learner and adapter. ^^
Jun11-11, 04:09 AM   #11
Recognitions:
Yes dear madam, it is too much for rounding errors. ;)
How did you get the angle of 28.5 degrees?
Both!
Aha, now I understand the head band.
It is both to protect your forehead from the slap, and to hide the bruises under it!
*slaps!*
*SLAPS!!*
*THUMPS!!!!*
*MONSTER THUMP!*
aw, aw, aw, aw, Aw, Aw, AW, AWW, AWWWW, AIEEEH!
More please
Jun11-11, 04:33 AM   #12
Recognitions:
Law of sines.
BP/sin(beta) = CP/sin(130)
When I know that CP = 641.45
And BP = 306.4
Jun11-11, 04:43 AM   #13
Recognitions:
Law of sines.
And BP = 306.4
All right, so how did you get BP and CP?
EDIT: Did you perhaps take BP from the drawing where you switched the letters A and B around?
EDIT2: You wrote in your problem that the angle is "psi", but actually that is "phi".
[itex]\phi[/itex] or [itex]\varphi[/itex] is phi
and [itex]\psi[/itex] is psi
Jun11-11, 07:10 AM   #14
Recognitions:
I most certainly did not switch A and B ar...no wait...wait...I most certainly did!
Your corrections are all correct-- as always. All solved ;)
thanks!
New Reply
Thread Tools
Similar Threads for: Finding the instantaneous axis of rotation (dynamics - circular and linear motion)
Thread Forum Replies
Instantaneous Axis of Rotation Introductory Physics Homework 4
Finding the instantaneous axis of rotation Introductory Physics Homework 7
rolling: is the instantaneous axis of rotation tangential? Differential Geometry 7
Instantaneous axis of rotation Classical Physics 6
Instantaneous axis of rotation Introductory Physics Homework 2
