Analytical solution of these coupled differential equations
The discussion revolves around solving coupled differential equations, with an initial condition provided. The original poster expresses difficulty in formulating their approach and understanding the problem context.
  • Participants question the original poster's familiarity with differential equations and suggest various methods for solving the problem, including finding eigenvalues, decoupling the equations, and using matrix exponentiation.
Some participants have offered guidance on potential methods to approach the problem, while others express concern about the original poster's lack of foundational knowledge in differential equations. There is an ongoing exploration of different solution strategies without a clear consensus on the best approach.
The original poster indicates that they found the problem online and did not receive formal instruction on it, which may affect their understanding and approach to solving the equations.
gursimran
I don't know how to type math equations of I have included a image file. Take initial conditiona as [0 1]
No idea
"No idea" isn't really an attempt...
What do you know of differential equations? Did you already solve things like this?
This is your homework problem- obviously your teacher thinks you should know how to do it yourself! Another problem is there there are several different ways to do this (finding eigenvalues and eigenvectors of a matrix or reducing to a single second order equation, or ...) and we have no idea which you have been taught.
My teacher dinnt give me this. I figured out this on internet. I'm bad in differential equations. I thought these coupled diff equations can be solved simultaneously and then integration but no such luck cos of one being exactly opp of other ..
First read http://en.wikipedia.org/wiki/Matrix_exponential then, the interesting part is the section of "applications" which solves a problem very much like yours!
Or failing matrix exponentiation, you can decouple them; Differentiate the top equation to find:
[tex] \frac{d^{2}A}{dt^{2}}=-10\frac{dA}{dt}+50\frac{dB}{dt}[/tex]
Now use the second equation to substitute for dB/dt, this will leave you with a B in your equation which can be gotten rid of by using the first equation. This will leave you with a second order differential equation for A.
oh thanks a lot, this is a much better and simple solution.
  • · Replies 21 ·
  • · Replies 25 ·
12K
