The components of a circuit with a voltage source and 2 resistors
The discussion focuses on a circuit analysis involving a voltage source of 10V and two resistors in series, R1 at 100 ohms and R2 at 150 ohms. The equivalent resistance (R(eq)) is calculated as 250 ohms, resulting in a current (i_s) of 0.04A. The voltages across the resistors are determined to be 4V across R1 and 6V across R2, with power dissipated by R1 at 0.16W and by R2 at 0.24W. The total power supplied by the source is 0.4W, confirming the calculations are accurate.
  • Understanding of Ohm's Law (V = iR)
  • Knowledge of power calculations in electrical circuits (P = iV)
  • Familiarity with series circuit configurations
  • Basic concepts of equivalent resistance
  • Study series circuit analysis techniques
  • Learn about power dissipation in resistors
  • Explore equivalent resistance calculations in parallel circuits
  • Investigate the implications of input resistance in circuit design
Electrical engineering students, circuit designers, and anyone involved in circuit analysis and design will benefit from this discussion.
Hooke's Law
The components of a circuit with a voltage source and 2 resistors ( series ) has the following values vs = 10V, R1 = 100 , R2 = 150. With i1 leaving the +ve vs and i2 leaving -ve vs ( i.e. i1 entering node A, i2 is entering in the opposite direction of i1 )
Find:
a) Currents through each resistor
b) Voltages across each resistor
c)power dissipated by each resistor
d) power supplied by source
e)equivalent resistance seen by the source
V=iR
P= iV
P-power
i- current
R- resistance
Since the circuit is in series i1=i2=is
vs = v1 + v2
vs = isR(eq)
R(eq) = R1 + R2 = 250 ohms
vs / R(eq) = is ====> is = (10v)/(250 ohms) = 0.04A
v1 =isR1
v1 = (0.04 A)(100 ohms) = 4V
v2 = isR2
v2 = (0.04A)(150 ohms) = 6 V
P1= isv1
P1=(0.04A)(4v)=0.16W
P2 =isv2 = (0.04 A) (6V)= 0.24 W
Ps = isvs
Ps = 0.4W
Is there something wrong in my calculations or concept? & what does it mean by "e)equivalent resistance seen by the source"?
Thanks
The calculations look OK.
e) is just asking for the total resistance, which you already worked out.
In this case, it is obvious, but sometimes it is important to say which point you are looking from when you talk about input resistance.
So, they say "as seen by the power supply" as if the power supply could "see" what resistance was across it.
  • · Replies 37 ·
  • · Replies 17 ·
  • · Replies 35 ·
