Simple problem, but having a bit of trouble
  • Thread starter Thread starter ramin86
    Bit
The discussion revolves around a physics problem involving a block being dragged over a rough horizontal surface by a force applied at an angle. Participants are examining the work done by various forces, including the normal and gravitational forces, and exploring concepts related to energy changes in the system.
  • Participants are attempting to calculate the work done by the normal and gravitational forces, questioning the assumptions about these forces and their relationship to displacement. There is discussion about the normal force not always being equal to the weight of the object due to the angle of the applied force.
Some participants have provided guidance on understanding the relationship between work and energy, particularly regarding gravitational potential energy and the effects of friction. There is a recognition of the importance of displacement direction in calculating work, and multiple interpretations of the problem are being explored.
Participants note that the block is on a rough horizontal surface, which raises questions about the relevance of gravitational potential energy in this scenario. There is also mention of the need to consider the work done against friction and how it relates to the total energy changes in the system.
ramin86
A 14.0 kg block is dragged over a rough, horizontal surface by a 87.0 N force acting at 20.0° above the horizontal. The block is displaced 6.50 m, and the coefficient of kinetic friction is 0.300.
(b) Find the work done on the block by the normal force.
J
(c) Find the work done on the block by the gravitational force.
J
I thought normal force was mg which turned out wrong.
For gravitational force, I tried force times delta r times cos theta, but that also turned out wrong as well.
[tex]W = Fdcos(\theta)[/tex]
What is the displacement in the direction of both of those forces? Think about it another way. The work is equal to the change in potential energy.
hmm...
not sure of what u mean lol
The magnitude of the work done by gravity is equal to the magnitude of the change in gravitational potential energy. I can't say anymore without flat out telling you :)
vsage, his problem says that the block is dragged over a rough, horizontal surface. Why should the change in gravitational potential energy enter into things at all? Is it not clearly zero, as is the answer to part c? Or is that what you were trying to get him to realize? It just seemed a roundabout way to attack the problem, that's all.
ramin, my two cents:
It's very important to realize that the normal force in any given problem is not always equal to the weight of the object. Granted, by Newton's third law, the ground should exert an upward force balancing the object's weight. However, what about the applied force? It is at an angle..., that means that some component of it is downward as well. How does this affect the normal force? Finally, what is the key point to remember in parts b and c? I'd say its that a force only does work if it causes some displacement in the same direction as it.
Because the question asked for the work done by gravity! vsage's suggestion is correct.
The point is to provide help and understanding, not just the answer! :smile:
Right.
You mean Newton's 2nd law.
In this example, the applied force has an upward component.
Right! (As vsage tried to point out in his first post.)
lol...I had a feeling it was zero, but for some reason I thought it'd be simple then.
I'm having a problem with the rest of the question thought:
(d) What is increase in internal energy of the block-surface system due to friction?
J
(e) Find the total change in the block's energy.
Not sure what to do here, I'm guessing you have to add up all the energies.
Find the work done against the frictional force.
Start by finding the work done by the applied force. Some of that work goes into the energy you found in part (d). What happens to the rest of it?
  • · Replies 47 ·
  • · Replies 32 ·
  • · Replies 27 ·
