Need help on a simple but frustrating integral
  • Context: Undergrad
  • Thread starter Thread starter Deuterium2H
    Integral
The discussion revolves around the integration of a specific differential equation related to motion, particularly focusing on the integral ds = [ v0 / (1 + kv0t) ] dt. Participants are seeking clarification on the integration process and the implications of the variables involved, particularly the nature of v0.
  • One participant expresses frustration with understanding elementary integrals and requests a step-by-step breakdown of the integration process.
  • Another participant suggests that the integral can be approached using the formula INT [ f'(x) / f(x) ] dx = ln |f(x)| + C, indicating a potential method to solve the integral.
  • A later reply confirms the proposed method but raises a concern about the nature of v0, questioning whether it is a function of time.
  • Another participant clarifies that v0 is actually a constant value, not a function of time, which resolves some confusion regarding the integration.
There is some initial uncertainty regarding the nature of v0, with differing views on whether it is a function of time. However, a consensus is reached that v0 is a constant value.
Participants discuss the implications of treating v0 as a function of time versus a constant, which affects the integration process. The discussion does not resolve all aspects of the integration technique itself.
Deuterium2H
I am reading Paul J. Nahn's excellent "Mrs. Perkins's Electric Quilt: and other Intriquing Stories of Mathematical Physics".
Unfortunately, while I can understand much of the complex analysis, I sometimes get hung up over the what I believe are rather elementary integrals which are never solved in a step by step fashion...but are just shown and then (with no explanation) given a solution. This can be a bit frustrating, especially if it has been years (decades) since one had advanced Calc, and has forgotten many of the common integral forms/solutions.
Anyways, I didn't even get through the damn Preface without encountering a problem.
We are given the following differential equation (integral):
k is a Constant of proportionality, and v0 is initial velocity, which obviously itself is a function of time.
The solution is given as:
s = ln[(1 + kv0t)(1/k)] + Z
How does one integrate the right side of the equation? I can get the sense that the solution will be a natural logarithm, due to the fact that we have a form INTEGRAL (dt/t).
Would someone be so kind as to break this down step by step for me. I am almost embarrassed to ask, but oh well. Thanks in advance!
Ah sugar...I think I might have remembered something. Is this one of those instances where we have an integral in which the numerator is a derivative of the denominator, and evaluated by the formula:
INT [ f'(x) / f(x) ] dx = ln |f(x)| + C ??
So,
s = (1/k) INT [ (kv0)/(1 + kv0t) ] dt
On further thought, I guess that does solve it. Would appreciate someone else's confirmation, however. Thanks again
Yup. That's just about right.
Thanks Char. Limit,
The only thing troubling me (still) is the fact that v0 is itself a funtion of "t"...and it almost seems like there is a partial derivative involved. However, if I just treat
d(kv0t)/dt = kv0, then it all works out simply.
Are you sure that v0 is a function of t?
EDIT: Initial velocity is actually NOT a function of time. Indeed, it's not a function at all! It's a constant value.
AHHHHH Yes!
Once again, thanks Char. Limit. You are absolutely right, and I had totally overlooked that.
  • · Replies 20 ·
