Air is a real substance for year 8 class
  • Thread starter Thread starter NDbogan
    Air Class Year
The discussion focuses on teaching year 8 students about the properties of air, emphasizing that air is a tangible substance that occupies space, has weight, and exerts pressure. Key experiments include using a beaker submerged in water, weighing an inflated basketball, and demonstrating air pressure with a cardboard-covered glass of water. The conversation highlights the importance of linking these concepts to the particle theory and the properties of gases, suggesting that educators should assess existing knowledge to build upon foundational concepts.
  • Understanding of basic physics concepts, particularly pressure and weight.
  • Familiarity with the particle theory of matter.
  • Knowledge of the properties of gases, including compressibility and phase transitions.
  • Experience with conducting simple scientific experiments and demonstrations.
  • Research the particle theory of matter and its application in explaining gas behavior.
  • Explore the concept of pressure in gases and how it relates to particle collisions.
  • Investigate additional experiments that demonstrate the properties of air and gases.
  • Review grade 8 science curriculum standards to align teaching methods with educational requirements.
Teachers, student educators, and science instructors looking to effectively communicate the properties of air and gases to middle school students.
NDbogan
So I'm teaching a year 8 (12 year olds) class on air or the properties of air. Does anyone have any ideas of what I should tell them or how to explain these properties in a understandable way?
In the document that I have been given it says that I must teach these following things:
Explain that air is a real substance that occupies space
Recall that a body of air has measurable weight.
Recall that air exerts considerable pressure on the surface of all things in it.
I will be doing a series of experiements to show these things, eg. turning a beaker upside down and push into water, weighing an almost fully inflated basketball then weighing it again after it is fully inflated, a glass filled with water place cardboard over the top and turn it upside down.
They will answer some questions on these experiements and try come up with some general rules explaining what has happened. Then I will go through what they should have seen and why what they saw occurred.
I have attached the powerpoint notes that I would like to use but I feel like there should be more I'm telling them but I don't know what.
All help appreciated!
Is this a typical grade 8 class, or a remedial course? If the former, I really don't think you have to explain to 12-year-olds that air is a real substance that takes up space. Grade 8 curriculums usually explain the particle theory and use it as a foundation to explain the properties of matter. This includes the 3 phases, phase transitions, and the properties of gases. For example, "pressure is caused by the collision of randomly-moving gas particles onto the container's walls" would be one of the concepts that they need to understand. "Gases are easily compressible because the particles are far apart, so inter-particle interactions are weak" would be another.
I think you should look at the course curriculum to see what they already know, then use it as a foundation to explain the properties of gases.
Thanks, some of them really do find it hard to understand so just related it all back to states of matter and did a number of labs. However some of them were quite prepared for kinetic theory, etc.
As a student teacher, my university supervisor was impressed.
