Why is 6k Ohms Reduced to 3k Ohms in Circuit Simplification?
  • Thread starter Thread starter JieXian
    Circuit Concept
The discussion centers on the reduction of 6k Ohms to 3k Ohms during circuit simplification using Thevenin and Norton equivalents. The transformation occurs when a 120V source with series resistors (4k + 2k Ohms) is converted into a Norton equivalent, resulting in a 20mA current source in parallel with a 6k Ohm resistor. This 6k Ohm resistor combines with another 6k Ohm resistor in parallel, effectively reducing the total resistance. The conversation clarifies the distinction between Thevenin and Norton equivalents, emphasizing that Thevenin resistance must be in series with the voltage source.
  • Understanding of Thevenin and Norton theorems
  • Basic knowledge of circuit analysis and simplification techniques
  • Familiarity with Ohm's Law and resistance calculations
  • Ability to interpret circuit diagrams and equivalent circuits
  • Study Thevenin's Theorem in detail, focusing on series and parallel configurations
  • Learn about Norton’s Theorem and its applications in circuit analysis
  • Practice circuit simplification problems involving multiple resistors
  • Explore advanced circuit analysis techniques using simulation tools like LTspice
Electrical engineering students, circuit designers, and professionals involved in circuit analysis and simplification will benefit from this discussion.
JieXian
Hi, I have a question relating to the image below.
http://img830.imageshack.us/img830/2173/elec.png/ From step 2 to 3, I get how 120V becomes 20mA but how is the 6k ohms affected? Why is it reduced to 3k ohms?
And from step 1 to step 2, why isn't it like below? Case 2b instead of 2a?
http://img835.imageshack.us/img835/9250/elech.png I arrived at the answer using a different technique but I would like to understand this one too.
Thank you very much.
In the first picture, between steps 2 and 3 the 120V source and its series 4k+2k Ohms are converted to their Norton equivalent: a 20mA source in parallel with 6k Ohms. Since all the components are in parallel, this 6k resistor can be combined with the existing 6k resistor at the left end of the circuit.
In the second drawing, the portion of the circuit for which the Thevenin equivalent is being found is the current source and everything to its right. The equivalent circuit (a voltage source in series with a 4k resistor) must be "tacked back on" at the same connection point.
Your figure 2b would put the Thevenin resistance of 4k in parallel with the voltage source. That is no what a Thevenin equivalent looks like; it must be in series.
I've never done a "partial" Thevenin or Norton (most of them are reduced to a source, an equivalent resistor and an open circuit. But now that I know that it's those 2 theorems I think I'll get it.
Thank you.
  • · Replies 38 ·
  • · Replies 27 ·
9K
