Not sure where to start(momentum problem, I think)
  • Thread starter Thread starter DLxX
The discussion revolves around two momentum problems involving a wagon with children jumping off and an explosion breaking a rock into pieces. The subject area is physics, specifically focusing on the conservation of momentum.
  • Participants explore the application of conservation of momentum in both scenarios. Questions arise regarding the initial and final momentum calculations, as well as the direction of the wagon's motion after the children jump off.
Some participants have provided guidance on using conservation of momentum and breaking down the problems into initial and final states. However, there is a lack of consensus on specific calculations, as indicated by differing opinions on the results.
Participants are working under the constraints of homework rules, which may limit the information shared. There is an emphasis on understanding the setup and assumptions related to the momentum problems.
DLxX
Please help me with this, as I'm not even sure where to start.
Two children are standing on a 150kg wagon which is at rest. The children jump off the wagon in opposite directions. The 40kg boy jumps off at 4m/s and the 50kg girl jumps off at 2 m/s. What is the speed and direction of the wagon?
As well as this one
An explosion blows a rock into three parts. Two pieces fly off at right angles to one another. A 1.0Kg piece moves at 12m/s and a 3kg piece moves at 8m/s. Determine the mass and direction of motion of the third piece if it has a speed of 30m/s.
Use conservation of linear momentum in both cases.
You are right, both of these questions are infact momentum questions. In either question, momentum must be conserved. For question 1, what is the momentum of the girl and the boy? What then must be the momentum of the wagon?
For question two, again, conservation of momentum. However, this time it gets a little harder. You have to break the momentum up into components and then solve it.
Lets divide the problem in two parts: initial and final.
INITIAL:
"Two children are standing on a 150kg wagon which is at rest."
So, the initial momentum is 0 because the entire system is at rest.
FINAL:
"The 40kg boy jumps off at 4m/s and the 50kg girl jumps off at 2 m/s"
Lets assume that the boy jumps from the left, and the girl from the right of the wagon, so the momentum of the boy is in -x direction and the girl's is in x direction. The wagon? We don't know yet.
The final momentum is [tex]\vec{p}_{boy} + \vec{p}_{girl} + \vec{p}_{wagon} = -40 \cdot 4 \vec{e_x} + 50 \cdot 2 \vec{e_x} + 150 \cdot \vec{v_w}[/tex]
The conservation of momentum says that [tex]\vec{p_{initial}} = \vec{p_{final}}[/tex], so
[tex]0 = -40 \cdot 4 + 50 \cdot 2 + 150 \cdot v_w \Rightarrow 60 = 150 \cdot v_w \Rightarrow v_w = 2.5 m/s[/tex]
And as v is positive, the wagon goes in the same direction the girl does.
The other problem is the same.
6/15=2.5?++
I think NOT.
14K
