Work and displacement of the point of application
The discussion revolves around the concept of work in physics, specifically in the context of a skater pushing against a wall and the implications of the wall's point of application in relation to work done. Participants are exploring the relationship between force, displacement, and the definition of work as it applies to this scenario.
  • Participants are questioning the reasoning behind the wall doing no work despite the skater's movement. There is a focus on the definition of the point of application of force and its motion, with some participants attempting to reconcile their understanding of work done by the wall versus the skater.
The discussion is active with various interpretations being explored. Some participants have provided insights into the definitions of work and displacement, while others express confusion about the relationship between the skater's movement and the wall's lack of work. A participant has indicated satisfaction with an explanation received, suggesting some productive direction has been achieved.
There appears to be a reliance on textbook definitions and examples, which may not fully address the participants' conceptual uncertainties. The discussion highlights the need for clarity on the definitions of work and the conditions under which it is considered to be done.
iampaul
I have this example from my physics books which says:
If a skater pushes against the wall and the skater moves, the wall does no work and the motion of the skater only results from the internal work of the skater. It also says that the wall does no work because there is no motion of its point of application, and this part is what i don't understand.
I am thinking that if the force from the wall acts on the skater, then the point of application of the force exerted by the wall is the skater. Since the skater did move, then there is motion of the point of application of the force from the wall.
Although I agree that the wall must have done no work, what confuses me is the reason why, which is about the motion of the point of application as the book tells.
Can anybody please help clear things up.Any help will be greatly appreciated, thanks!
work and displacement of the point of application
In general, the work done by a force is given by
[tex]W = \int \vec{F} \cdot d\vec{x}[/tex]
If you're in a non-calculus based course, you typically have constant forces and this boils down to
[tex]W = F\Delta x[/tex]
If the wall did not move, the wall could not have done work, even if a force was applied. If this is confusing, think of yourself standing on the ground. The Earth is exerting a force on you and you on it, but just by standing there no work is done because no displacements occur vertically.
"If the wall did not move, the wall could not have done work,..."
What I only understand is that if the wall didn't move then the skater did no work to the wall, but i can't still understand why the wall couldn't have done work to the skater based on the reason that there is no motion of its point of application which is the skater and the skater moved so there is displacement.
Since the point of contact of force between the skaters hands and the wall doesn't move, then the wall does no work. The skater's arms are acting similar to a spring and that is the source of the work.
I'm not entirely sure what you mean "there is no motion of its point of applications", but the skater did move so work was done, but it was only done by the skater.
thanks a lot! now i get it!
  • · Replies 90 ·
