Calculating Mu for Unacceptable Dye Discharge in Paint
  • Thread starter Thread starter tink
    Discharge Paint
The discussion focuses on calculating the mean (mu) for dye discharge in paint to ensure that only 1% of cans exceed 6 mL of dye. The standard deviation is given as 0.4 mL, and the z-score for the 99th percentile is approximately 2.33. By applying the normal distribution formula, the calculated value for mu is 5.068 mL. This setting will effectively limit unacceptable dye discharge to the specified threshold.
  • Understanding of normal distribution and z-scores
  • Familiarity with statistical formulas, particularly for mean and standard deviation
  • Basic knowledge of probability and percentiles
  • Ability to use z-score tables for statistical analysis
  • Learn about normal distribution and its applications in quality control
  • Study how to use z-scores in various statistical scenarios
  • Explore advanced statistical tools for process optimization
  • Investigate the implications of standard deviation in manufacturing processes
Quality control engineers, statisticians, and anyone involved in manufacturing processes that require precise measurements of material discharge.
tink
OK, here is the question... its probably simple but i can't figure it out.
A machine used to regualte the amount of dye dispensed for mixing shades of paint can be set so that it discharges an average of mu milliliteres(mL) of dye per can of paint. The amount of dye discharged is known to have a normal distribution with standard deviation of 0.4 mL. If more than 6 mL of dye are discharged when making a certain shade of blue paint, thd shade is unacceptable. Determine the setting for mu so that only 1% of the cans of paint will be unacceptable.
Thanks a lot!
Ok, so you first want to find how many standard deviations you can be away from your given mu so that only 1% come above the limit of 6 mL, given that standard deviation is two sided, you must find the number of standard deviations you can be away from the mean such that only 2% of the data does not fall within the given area. Then, you can take this number, which is the number of standard deviations the data is allowed to deviate from the median and multiply it by the given standard deviation, .4 mL This should give you a mu for which only 1% of your results will come above 6 mL.
~Lyuokdea
To calculate mu for unacceptable dye discharge in paint, we need to use the normal distribution formula and set the probability of unacceptable cans to 1%. This means that we are looking for the value of mu that corresponds to the 99th percentile of the normal distribution curve.
Using a z-score table, we can find that the z-score for the 99th percentile is approximately 2.33. We can then plug this value into the formula for the normal distribution:
z = (x - mu)/sigma
where z is the z-score, x is the value we are looking for (in this case, 6 mL), mu is the mean (which we are trying to find), and sigma is the standard deviation (which is given as 0.4 mL).
Rearranging the formula, we get:
mu = x - (z * sigma)
Plugging in the values, we get:
mu = 6 mL - (2.33 * 0.4 mL)
Simplifying, we get:
mu = 5.068 mL
Therefore, the setting for mu should be 5.068 mL to ensure that only 1% of cans of paint will have unacceptable dye discharge.
  • · Replies 105 ·
15K
