Derivative of 1/x the old fashioned way
  • Thread starter Thread starter 1MileCrash
    Derivative
The problem involves finding the derivative of the function f(x) = 1/x using the limit definition of the derivative. Participants are exploring algebraic manipulation to simplify the expression and arrive at the derivative.
  • Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the limit expression and the need to simplify the subtraction of fractions. There is a focus on correctly handling the algebra involved in the limit process.
Some participants have offered guidance on simplifying the limit expression, while others express frustration with the algebraic manipulation. There is a recognition of the need to divide through by h and concerns about handling complex fractions.
Participants are required to show their work and use the limit definition of the derivative, which may impose constraints on their approaches. There is an emphasis on arriving at the derivative through algebraic means without skipping steps.
1MileCrash
f(x) = 1/x
Find the derivative
f'(x)= lim h->0
[f(x+h) - f(x)] / [h]
I MUST show work and use that formula to arrive at the derivative (1/x^2)
I can't figure out the algebra.
I rearrange it countless ways..
[1/(x+h) - 1/x] - (1/x)] / [h]
ETC.
But I can NEVER find a way to algebraically arrive at the derivative! Ever!
What would you guys do to algebraically solve this??
You must calculate
[tex]\lim_{h\rightarrow 0}{\frac{\frac{1}{x+h}-\frac{1}{x}}{h}}[/tex]
First simplify it (to the point where there's only one fraction, instead of three fractions).
Rearranging your limit expression is not necessarily going to help unless you can do the subtraction [1/(x+h) - 1/x] correctly. Show what you get for this calculation.
That gets me no where.
(x-x-h)/(x^2+hx)
or
-h / (x^2+hx)
Yes it will :smile:
(x-x-h)/(x^2+hx)
or
-h / (x^2+hx)
And now you still need to divide through h...
(x-x-h)/(x^2+hx)
or
-h / (x^2+hx)
This is not the complete quotient. This is just the simplification of the numerator, 1/x - 1/(x + h)
Dividing by h is equivalent to multiplying by 1/h.
That's where I'm stuck.
How can I get rid of the complex fraction here?
"Dividing through h" doesn't seem possible.
[tex]\lim_{h\rightarrow 0}{\frac{\frac{1}{x+h}-\frac{1}{x}}{h}} = \lim_{h \to 0} \frac{-h}{x^2 + hx}\cdot \frac{1}{h}[/tex]
Can you simplify a bit more and then take the limit?
NOW I see! Thanks!
-h / hx^2 + h^2x
h(-1) / h(x^2+hx)=
(-1) / x^2 + hx
as h approaches 0, hx approaches zero, leaving me with x^2 in the denomenator for a final result of
- 1/x^2
1MileCrash said:
NOW I see! Thanks!
-h / hx^2 + h^2x
h(-1) / h(x^2+hx)=
(-1) / x^2 + hx
- 1/x^2
Right!
  • · Replies 22 ·
  • · Replies 16 ·
