New Reply
Magnetic field inside a cylinder which is rotating in a non-constant angular velocity
Share Thread Thread Tools
Jun17-11, 12:12 AM   #1
A hollow cylinder of length L and radius R, is madeout of a non-conducting material, is charged with a constant surface charge σ, and is rotating, along its axis of symmetry, with an angular velocity w(t) = αt.
Q:What is the magnetic field inside the cylinder?
2. Relevant equations
Maxwell correction for Ampere law.
3. The attempt at a solution
The answer in the manual is B = μαtRσ
Where μ is ofcurse μ zero. [ the magnetic constant ].
The manual's solution makes perfect sense if I knew that the circular electric field which is induced by the fact that the magnetic field is changing in time is constant.
because then i could say that that the displacement current density is zero.
Q: How can derive that the circular electric field, induced by the changing -in-time magnetic field, is not changing with time?
Thanks in advance
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Jun17-11, 03:00 AM   #2
What is I?
its the relation betwwen the charge (you know it from sigma) and the period (you know it from w)
The charge inside the cylinder its Sigma*A(r) (and not all A!!)
What is the integral of B*ds ?
its the product of B and the scale circuits that thir radius its r (r<R)
You need to replace those sizes into Amper equation.. and get B(r)
Jun17-11, 05:24 AM   #3
Thanks for the reply.
But it did not address my question,
I would like to know why in this problem there is a certainty that the Electric field is not changing with time ?
id est, look at Ampere's Law after Maxwell correction:
[itex]\nabla \times \mathbf{B} = \mu_0\mathbf{J} + \mu_0 \varepsilon_0 \frac{\partial \mathbf{E}} {\partial t}\ [/itex]
and of course, the integral form of this equation:
[itex]\oint_{\partial S} \mathbf{B} \cdot \mathrm{d}\mathbf{l} = \mu_0 I_S + \mu_0 \varepsilon_0 \frac {\partial \Phi_{E,S}}{\partial t} [/itex]
I could, with rather ease, derive the manual's solution if I knew that [itex] \frac{\partial \mathbf{E}} {\partial t} \ [/itex] is zero.
Any notions about why E is constant in time?
Thanks in advance
Jun17-11, 07:36 AM   #4
The answer is simple. (I will call sigma -> rho)
if dE/dt (partial derivative) = 0
==> (Gauss law)
d[itex]\rho[/itex]/dt = 0
==> (math)
[itex]\rho[/itex] is constant in time. (stationary current)
And you can see in the problem data, that they didn't say anything about the function [itex]\rho[/itex] .
Jun18-11, 02:48 AM   #5
Again, thanks for the reply.
The [itex] \nabla \cdot \mathbf{E} = \frac {\rho} {\varepsilon_0}[/itex] formula applies only to E filed that are not circular. [ I mean in order to derive the total electric field inside the cylinder you will have to find the E in the theta direction as well]
According to Faraday's Law:
[itex] \nabla \times \mathbf{E} = -\frac{\partial \mathbf{B}} {\partial t}[/itex]
Which means that a changing in time magnetic field induces a circular E field.
How can I infer that the circular E field is not changing by time? [ prior to calculating the magnetic field - because then i just use faraday law to see that]
New Reply
Thread Tools
Similar Threads for: Magnetic field inside a cylinder which is rotating in a non-constant angular velocity
Thread Forum Replies
Magnetic field inside a cylinder which is rotating in a non-constant angular velocity Advanced Physics Homework 0
Magnetic field of long rotating dielectric cylinder with built in radial polarization Advanced Physics Homework 3
Does Torque act on a disc rotating with constant angular velocity Classical Physics 4
Magnetic field of rotating cylinder Advanced Physics Homework 6
Rotating cylinder, how long will it take before the angular velocity is halved Advanced Physics Homework 2
