How Do OH Groups Affect Solubility and What Solvents Clean Paints?
The discussion focuses on the solubility of alcohols in water, specifically examining how hydroxyl (OH) groups in sucrose and glycerin enhance their water solubility through hydrogen bonding. For cleaning latex paint, polar solvents like water or rubbing alcohol are recommended due to their compatibility with water-based paint. In contrast, non-polar solvents such as mineral spirits or turpentine are necessary for cleaning enamel (alkyd) paint, as these oil-based paints require non-polar solvents for effective removal.
  • Understanding of polar and non-polar molecules
  • Knowledge of hydrogen bonding
  • Familiarity with solvent types (polar vs. non-polar)
  • Basic chemistry concepts related to solubility
  • Research the properties of polar and non-polar solvents
  • Learn about hydrogen bonding in chemistry
  • Explore the differences between water-based and oil-based paints
  • Investigate the environmental impact of using solvents like mineral spirits and turpentine
Chemistry students, paint professionals, and anyone interested in understanding solvent interactions and paint cleaning methods.
dajugganaut
hi. I am in grade11 chemistry and have a few questions regarding alcohols and solubility in water (polar/non-polar molecules).
1) how does the OH groups in surcrose and glycerin help them to be water soluble?
2) what would you use to clean your hands and the paint brush after painting with latex paint? explain.
3) what solvent would you use to clean your hands and the paintbrush after painting with enamel(alkyd) paint? explain
if you could help me thatd be great! thanks=D
You posted this in Chemistry (which is where it should be) already. Please respect the rules of this forum and do not double post.
Hi there! I'd be happy to help answer your questions about alcohols and solubility in water.
1) The OH groups in sucrose and glycerin are polar groups, which means they have a slightly positive and slightly negative end. Water is also a polar molecule, with a slightly positive end (hydrogen) and a slightly negative end (oxygen). This allows for hydrogen bonding between the OH groups in sucrose and glycerin and the water molecules, making them water soluble.
2) For cleaning your hands and paintbrush after using latex paint, you would want to use a polar solvent such as water or rubbing alcohol. Latex paint is water-based, so it will dissolve in water or rubbing alcohol. These solvents will help to break down and remove the latex paint from your skin and paintbrush.
3) For cleaning your hands and paintbrush after using enamel (alkyd) paint, you would want to use a non-polar solvent such as mineral spirits or turpentine. Enamel paint is oil-based, so it will not dissolve in water. Non-polar solvents are needed to dissolve and remove the enamel paint from your skin and paintbrush.
I hope this helps! Let me know if you have any other questions. Good luck with your studies!
10K
