Cauchy Sequences - Complex Analysis
The discussion centers on the properties of Cauchy sequences and continuity in the context of complex analysis. It establishes that a function f: G → Complex Plane is continuous if for every sequence C of complex numbers in G converging to a limit in G, the limit of f(C) equals f of the limit of C. Furthermore, it confirms that every Cauchy sequence in the complex plane is convergent, emphasizing the need for a solid understanding of the Cauchy sequence definition. Lastly, it asserts that every Cauchy sequence of integers has a limit in the set of integers (Z), highlighting the completeness of closed sets in complete spaces.
  • Understanding of complex functions and their continuity
  • Familiarity with the definition of Cauchy sequences
  • Knowledge of the completeness property of real numbers
  • Basic concepts of limits and epsilon-delta definitions in analysis
  • Study the epsilon-delta definition of continuity in complex analysis
  • Learn about the completeness of metric spaces and its implications for Cauchy sequences
  • Explore the relationship between Cauchy sequences and convergence in various number systems
  • Investigate the properties of closed sets in complete spaces and their relevance to Cauchy sequences
Students and professionals in mathematics, particularly those focusing on complex analysis, real analysis, and functional analysis. This discussion is beneficial for anyone seeking to deepen their understanding of continuity, limits, and Cauchy sequences.
MurraySt
Hope someone could give me some help with a couple of problems.
First:
Proof of -
A function f:G -->Complex Plane is continuous on G iff for every sequence C(going from 1 to infinity) of complex numbers in G that has a limit in G we have
limit as n --> infinity f(C) = f(limit as n --> infinity C)
Should I use the definition of the complex limit? Limit proofs always scare me.
Next I need to provide a proof of "Every Cauchy sequence in the complex plane is convergent"
I'm a little shaky on the definition of a Cauchy sequence if someone could provide one in more layman's terms that would be greatly appreciated.
And lastly, were asked to "show that every Cauchy sequence of integers has a limit in the set of integers (Z)
Again I feel with a better understanding of the definition of a Cauchy sequence I would have a shot at getting it.
Hi MurraySt! :smile:
First:
Proof of -
I fear that you'll have to do some epsilon-delta things here. You'll need to prove
[tex]\forall \varepsilon>0:\exists n_0:\forall n\geq n_0:~|f(x)-f(x_n)|<\varepsilon[/tex]
Apply the definition of continuity here and the definition of [itex]x_n\rightarrow x[/itex].
Do you know the corresponding theorem for the real numbers? I.e. do you know that R is complete? That should help you here.
Intuitively, a Cauchy sequence is a sequence such that the terms lie closer and closer together. It are sequences that should converge in a space that's nice enough. And nice enough means complete here.
Prove in general that a closed set of a complete space is complete.
micromass gave a good intuitive definition, so I'll give a slightly more technical one. A sequence is Cauchy if, given any arbitrarily small positive number epsilon, we can find a point in the sequence after which all terms of the sequence are closer together than epsilon. Formally, for any [itex]\epsilon >0[/itex] there is some N such that for any [itex]m,n \geq N[/itex], [itex]|s_m - s_n| < \epsilon[/itex].
This seems like a little overkill for this problem (which is not to say it wouldn't work). The integers are a discrete set, so if we have, say |a - b| < 1/2 for integers a and b, what else can you say about a and b?
  • · Replies 24 ·
