Do These Solutions Accurately Solve Basic Momentum Problems?
  • Thread starter Thread starter justagirl
    Momentum
The discussion centers on the application of the conservation of momentum in various physics scenarios. Participants confirm that when rain falls into a boxcar on a frictionless track, the momentum of the system increases due to the added mass. They also clarify that in collisions, while momentum is conserved, the sum of the velocities is not necessarily constant. Additionally, the explosion of a projectile into two fragments illustrates the need to consider vector components when calculating final velocities, with the lighter fragment's speed determined to be 5V.
  • Understanding of conservation of momentum principles
  • Familiarity with vector quantities in physics
  • Basic knowledge of projectile motion and explosions
  • Ability to solve algebraic equations involving multiple variables
  • Study the principles of conservation of momentum in closed systems
  • Learn how to resolve vector quantities in two dimensions
  • Explore the effects of mass and velocity in collisions
  • Practice solving problems involving projectile motion and explosions
Students of physics, educators teaching momentum concepts, and anyone interested in understanding the dynamics of collisions and projectile motion.
justagirl
Hey, just want to double check on these:
Rain falls vertically into an open boxcar coasting freely on a horizontal frictionless track. As a result the momentum of the system consisting of the boxcar plus accumulated water increases.
- I said true - since there is no friction, velocity would not decrease. However, mass increases and momentum increases.
In any collision between one object initially moving with velocity vector v1 and another object initially moving with velocity vector v2, the vector (v1 + v2) must be conserved, since momentum is conserved during the collision and the total mass of the system is also conserved.
I said false, since the more massive cart would influence the final direction and change the initial vector.
A projectile of mass M is moving in the +x direction with speed V when it explodes into two fragments: a lighter one having mass M/4 and a heavier one having mass 3M/4. The heavier fragment moves in the +y direction with speed V. What is the speed of the lighter fragment? (Assume there are no external forces acting on the system).
- I said it's V, since it has to balance out the initial momentum.
Are those right??
Thanks!
1. Not sure if I agree quite yet. It is hard for me to imagine the boxcar would be moving at the same velocity if many times its weight in raindrops fell into the cart. Additionally, the nature of fluids is to move in a way that is not uniform so the momentum of particles jostling around tends to cancel the momentum of other particles.
2. You're right I think. Conservation of Momentum is sort of a "weighted average" of all the bodies involved.
3. Since the system was originally moving at the speed V on the +x direction and 0 in the +y direction, the y momentums must cancel after the projectile explodes.
ONE OF THE PHYSICS LAW, CONSERVATION OF MOMENTUM:
Momentum in a system is always conserved: m1v1i+m2v2I=m1v1f+m2v2f
No, not necessarily. B/c we have conservation of MOMENTUM, it means that sum of the products of mass and velocity in a system, containing any number of objects, is constant. Algebraically, it doesn't mean that the sum of the velocities are constant too.
The speed is 5V.
Notice that momentum is a vector quantity, not scalar. It means that you should take the directions (and angles) of the velocities into account.
For solving this question, you should write 2 equations, one for x direction and one for y direction, and solve them individually, than find the whole magnitude ( (a^2+b^2) ^ (1/2) )
  • · Replies 40 ·
  • · Replies 16 ·
