Polar to cartesian coordinates for stream function
The discussion focuses on converting polar coordinates to Cartesian coordinates for a velocity field characterized by V_r=0 and V_theta=cr. The equations of the streamlines are derived using the relationships x=rcos(theta) and y=rsin(theta). Despite the radial component being zero, the presence of a tangential component results in an x-component in the Cartesian system, which is clarified through the relationships between the variables. Participants seek assistance in understanding the translation process from polar to Cartesian coordinates.
  • Understanding of polar coordinates and their relationship to Cartesian coordinates.
  • Familiarity with velocity fields in fluid dynamics.
  • Knowledge of basic calculus, particularly derivatives.
  • Experience with vector components in physics.
  • Study the conversion formulas between polar and Cartesian coordinates in depth.
  • Learn about stream functions and their applications in fluid dynamics.
  • Explore the implications of velocity components in different coordinate systems.
  • Investigate the use of parametric equations in describing motion in physics.
Students in physics or engineering, particularly those studying fluid dynamics, as well as educators looking for clear explanations of coordinate transformations.
xzi86
Consider a velocity field where the radial and tangenetial components of velocity are V_r=0 and V_theta=cr, respectively, where c is a constant. Obtain the equations of the streamlines.
x=rcos(theta)
y=rsin(theta)
I know how to obtain the equations of the streamlines. I don't know how to translate the polar coordinates into cartesian. Since V_r=0, wouldn't there be no x-component? But looking at the textbook solution, there is an x component. Any help would be appreciated. Thanks.
hi xzi86! :smile:
(try using the X2 icon just above the Reply box :wink:)
Vr = 0 means there is no radial component …
in which (x,y) direction is the radial direction? :wink:
x=x(r,[itex]\theta[/itex])=rcos[itex]\theta[/itex]
y=y(r,[itex]\theta[/itex]=rsin[itex]\theta[/itex]
You are given
V[itex]_{r}[/itex]=[itex]\frac{dr}{dt}[/itex]=0
V[itex]_{\theta}[/itex]=[itex]\frac{d\theta}{dt}[/itex]=cr
How do you calculate
V[itex]_{x}[/itex]=[itex]\frac{dx}{dt}[/itex]
and
V[itex]_{y}[/itex]=[itex]\frac{dy}{dt}[/itex] ?
10K
