Need Help with HS Physics Problem? Calculate Total Distance Traveled
  • Context: High School
  • Thread starter Thread starter SpeedeRi2
    Physics
The discussion revolves around solving a high school physics problem involving the calculation of total distance traveled by an object moving at different velocities over specified time intervals. The problem includes uniform motion and requires understanding of distance and displacement concepts.
  • Homework-related
  • One participant asks for help with a physics problem involving an object moving at 10 m/s for 3 seconds and then at 5 m/s for 2 seconds.
  • Another participant suggests using the formula d = vt to calculate distance, emphasizing its applicability to the problem.
  • A participant warns about the distinction between distance and displacement, noting that displacement is a vector quantity.
  • One participant mentions that if a speed-time graph is created, the area under the graph would represent the total distance traveled.
  • A participant reports obtaining two different answers (50 mph and 65 mph) using different equations, expressing uncertainty about their correctness.
  • Another participant reiterates the need to calculate the distance traveled during each segment of the motion before summing them for the total distance.
The discussion contains multiple viewpoints on how to approach the problem, with no consensus on the correct method or final answer. Participants express uncertainty and differing interpretations of the problem.
Some participants highlight the importance of distinguishing between distance and displacement, which may affect the interpretation of the problem. There is also mention of different equations leading to varying results, indicating potential misunderstandings or misapplications of concepts.
SpeedeRi2
Can u help me solve this HS Physics problem?
Any help will be appreciated! :smile:
1.) An object travels in a straight line at a uniform velocity of 10 m/s for 3 seconds and then travels for 2 seconds at constant speed of 5 meters per second in the same direction. Calculate the total distance traveled.
If I move at 10 m/s, that means I move a distance of 10 metres every second. So if I travel at that velocity for 3 whole seconds, how far have I gone? Do you see that d = vt is all you need for this problem. More importantly, do you see why it applies from my description?
lol becareful distance and displacement displacement is a vector
He does mention its in the same direction. If you have graph of the above data, then the area under the graph equals distance travelled(speed-time graph)
so i haev 2 answers one 50 mph and one 65 mph , they probley are both wrong, but i used two different equations and obtained two different answers!?
So how far does it travel in those first 3 seconds?
And how far does it travel in these 2 seconds?
So... what's the total distance traveled?
  • · Replies 138 ·
9K
  • · Replies 18 ·
10K
10K
