Thread Closed
friction problem
Share Thread Thread Tools
Nov1-04, 02:59 PM   #1
Recognitions:
Gold Membership Gold Member
friction problem
Figure 6-36: http://www.webassign.net/walker/06-36alt.gif
5. [Walker2 6.P.071.] Two blocks, stacked one on top of the other, slide on a frictionless, horizontal surface (Figure 6-36), where M = 5.0 kg. The surface between the two blocks is rough, however, with a coefficient of static friction equal to 0.47.
If a horizontal force F is applied to the bottom block, what is the maximum value F can have before the 2.0 kg top block begins to slip?
The answer in the back of the book is 32 N. But that's not what I get. I get the same wrong answer 2 different ways:
friction = mu * mg
friction = 0.47 * 2 * 9.81
friction = 9.2214 N
at this point, I'm stuck.
I'd like to say that if pushing the 2 kg block with a force of 9.2214 will move it, then how much harder would I have to push a 5 kg block to make its push equivalent to the 2 kg push.
9.2214 * (5/2) = 23.0535 which is the wrong answer.
Or I could do it like this:
f=ma
9.2214 = 2 * a
a = 4.6107
now use this for a for the 5 kg block
F = ma
F = 5 * 4.6107
F = 23.0535 which is exactly what I got before and it is wrong
Any thoughts...??
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Nov1-04, 03:15 PM   #2
Mentor
You are very close. What is the maximum acceleration that the top block can have? (You already figured that out--that's when the frictional force on it is at maximum.) Now treat the two blocks as a single object (why not?). What force F is required to accelerate both blocks to that value?
(One of your mistakes was using F = ma, but not using the net force on the object. If you treat the bottom block by itself -- nothing wrong with that! -- don't forget that there are two horizontal forces on it. Recall Newton's 3rd law.)
Nov1-04, 03:31 PM   #3
Recognitions:
Quote by Doc Al
Thanks, Doc (again!)
lol... I feel so stupid for not realizing that I'm pushing 7kg, and not 5 !!! I stared at this for an hour.
Thread Closed
Thread Tools
Similar Threads for: friction problem
Thread Forum Replies
Friction Problem Introductory Physics Homework 6
Friction Problem Introductory Physics Homework 1
friction problem Introductory Physics Homework 5
Friction problem Introductory Physics Homework 6
Need help with friction problem Introductory Physics Homework 1
