Another Question Regarding Power Series
The discussion focuses on the derivation of a power series involving alternating sums and factorials using Mathematica. The original series is simplified by combining terms and factoring, leading to a new expression that can be evaluated through a change of index. The final result demonstrates the transformation of the series into a more manageable form, confirming the validity of the approach taken by the participants.
  • Understanding of power series and convergence
  • Familiarity with factorial notation and operations
  • Proficiency in using Mathematica for mathematical computations
  • Knowledge of series manipulation techniques, including index changes
  • Explore advanced series manipulation techniques in Mathematica
  • Learn about convergence tests for power series
  • Study the properties of alternating series and their applications
  • Investigate the use of index changes in series summation
Mathematicians, students studying advanced calculus, and anyone interested in series analysis and manipulation techniques using Mathematica.
DivGradCurl
I used Mathematica to confirm that
[tex]\sum _{n=0} ^{\infty} \left[ \frac{\left( -1 \right) ^n \left( 2n \right) x^{2n+1}}{n! \left( n+1 \right) ! 2^{2n+1}} \right] + \sum _{n=0} ^{\infty} \left[ \frac{\left( -1 \right) ^n \left( 2n \right) \left( 2n+1 \right) x^{2n+1}}{n! \left( n+1 \right) ! 2^{2n+1}} \right] = - \sum _{n=0} ^{\infty} \frac{\left( -1 \right) ^n x^{2n+3}}{n! \left( n+1 \right) ! 2^{2n+1}}[/tex]
Does anyone know how to obtain it directly?
Thank you.
Sure, combine the series on the left and notice that when n=0, the coefficient vanishes to get:
[tex]\sum _{n=1} ^{\infty} \left[ \frac{\left( -1 \right) ^n \left( 2n \right) (2n+2) x^{2n+1}}{n! \left( n+1 \right) ! 2^{2n+1}} \right][/tex]
Factor the numerator slightly:
[tex]\sum _{n=1} ^{\infty} \left[ \frac{\left( -1 \right) ^n \left( n \right) (n+1)2^2 x^{2n+1}}{n! \left( n+1 \right) ! 2^{2n+1}} \right][/tex]
Do some light cancelling, write our power of x in a funny way and let's pull out a -1 for fun:
[tex]-\sum _{n=1} ^{\infty} \left[ \frac{\left( -1 \right) ^{n-1} x^{2(n-1)+3}}{(n-1)! \left( (n-1)+1 \right) ! 2^{2(n-1)+1}} \right][/tex]
You are now a change of index variable away from glory.
Thanks a lot! It makes sense now.
