Diagonalization of symmetric bilinear function
The discussion revolves around the diagonalization of symmetric bilinear functions, specifically examining the implications of the duality principle and the conditions under which a bilinear form can be represented as a diagonalizable matrix. Participants explore examples and clarify terminology related to diagonalization and orthonormalization.
  • Some participants assert that a bilinear function \(\theta:V\times V \rightarrow R\) can be represented as a diagonalizable matrix \(T\) with entries defined by \(\theta(\alpha_i,\alpha_j)\).
  • It is proposed that the values of \(\theta(\alpha_i,\alpha_i)\) can be 0, 1, or -1, with a specific example showing that \(\theta(\alpha_i,\alpha_i)=-1\) arises in certain contexts.
  • One participant introduces the idea that the real numbers are not algebraically closed, suggesting that diagonalization may yield different results in the complex numbers.
  • Another participant presents examples of bilinear forms, illustrating how orthogonal bases can be derived and how normalization affects the diagonalization process.
  • A question is raised regarding the distinction between "diagonalizable" and "orthonormalizable," with a focus on the mathematical operations involved in each process.
Participants express differing views on the relationship between diagonalization and orthonormalization, indicating a lack of consensus on terminology and the implications of the examples provided.
There are unresolved questions regarding the definitions and processes of diagonalization versus orthonormalization, as well as the implications of using real versus complex numbers in these contexts.
yifli
According to duality principle, a bilinear function [itex]\theta:V\times V \rightarrow R[/itex] is equivalent to a linear mapping from V to its dual space V*, which can in turn be represented as a matrix T such that [itex]T(i,j)=\theta(\alpha_i,\alpha_j)[/itex]. And this matrix T is diagonalizable, i.e., [itex]\theta(\alpha_i,\alpha_i)=0,1,-1[/itex].
I don't understand how come [itex]\theta(\alpha_i,\alpha_i)=-1[/itex]
Hi yifli! :smile:
That -1 arises because the real numbers are not algebraically closed. In the complex numbers, we have that T is diagonalizable with 0 or 1 on the diagonal.
Basically, saying that theta is diagonalizable is equivalent to picking an orthogonal base for theta. Let's pick an example:
[tex]\theta(x,y)=xy[/tex]
This is a bilinear form and the following base is orthogonal: v=(5,0), w=(0,10). However, we can normalize this by doing:
[tex]\frac{v}{\sqrt{\theta(v,v)}}[/tex]
This yields the base (1,0), (0,1). So we have a diagonalizable matrix with 1's on the diagonal.
However, let's pick
[tex]\theta(x,y)=-xy[/tex]
this is a bilinear form. An orthogonal base for this is again v=(1,0), w=(0,1). However, for this we have
[tex]\theta(v,v)=-1[/tex]
So if we try to normalize this, we get
[tex]\frac{v}{\sqrt{\theta(v,v)}}=\frac{v}{\sqrt{-1}}[/tex]
but this cannot be in the real numbers. It is possible in the complex number, however, and this yields the orthonormal base (-i,0),(0,-i). The norms for this basis are 1, thus we get the matrix with 1's on the diagonal.
Uhm, are you guys confusing the terms "diagonalizable" and "orthonormalizable", or is it me, the one confused? When you diagonalize a matrix, don't you multiply on the left and right with a matrix and it's inverse? Instead, in orthonormalization, don't you multiply on the left and right with a matrix and it's transposed? (that's exactly what happens in Micromass's last example)
Indeed, I've edited my post. Sorry yifli!
