New Reply
Can I use 24 Volts input to a car ignition coil?
Share Thread Thread Tools
Jun27-11, 12:42 AM   #1
I'm feeding the current in pulses via 50v 6800 mfd capacitor. Will it destroy the ignition coil instantly, or will just overheat it?
It won't be for automotive use but for general high voltage experiments. As long as instant destruction is a remote possibility, it's easy enough to mitigate overheating, and will proceed using 24V power, thanks!
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> NASA: Austin, calling Austin. 3-D pizzas to go
>> Research suggests modular design competence can benefit new product development
>> Army ground combat systems adopts tool for choosing future warfighting vehicles
Jun27-11, 09:31 AM   #2
Look into CDI ignition systems. They put short duration pulses much higher than 12 volts into ignition coils. Might give you an idea of what you can get by with.
Jun27-11, 02:05 PM   #3
Do it until you release the smoke. Wear safety glasses....
At some point you will find the breakdown voltage of the coil secondary, but it's likely quite a bit higher than "absolutely" necessary. Duty cycle and (over) heating will be of interest. I did once use dueling ignition coils to run a spark gap, but have no memory of how hard I pushed their primaries.
Jun27-11, 10:01 PM   #4
Thanks for your responses so I guess it will likely work. I think I might make a heat sink fan for it. Pulses will be in the micro second range with much larger duration of 'no current' in between.
I've once run several high energy pulses before in an open coil with pvc insulation. Really small gauged wires and passed 30 KV coming from a 2 liter Leyden Jar. Took only few pulses before the insulator melted and the coil shorted.
Not sure how an ignition coil + 30 volts + capacitor would respond so thanks for sharing your own experiences. Going ahead and test it! Thanks! :D
New Reply
Thread Tools
Similar Threads for: Can I use 24 Volts input to a car ignition coil?
Thread Forum Replies
tesla coil secondary coil wrapped around primary coil Electrical Engineering 6
Dual Ignition Coil Sparks for Biology Experiment Electrical Engineering 0
Magneto Vs. Ignition Coil Mechanical Engineering 10
How to convert 5 volts to 12 volts for a USB Motor Electrical Engineering 10
Voltage pulse from ignition coil ?? Electrical Engineering 14
