Proton travelling through a magnetic field
The discussion revolves around a problem involving a proton traveling through a magnetic field, focusing on its deflection and motion characteristics. The participants explore the calculations related to force, radius of motion, and the period of revolution, while seeking to determine the instantaneous position of the proton after a specific time interval.
  • Participants discuss the calculation of force on the proton due to its charge and velocity, and the subsequent determination of the radius of its circular path. Questions arise regarding the method to find the instantaneous position and direction after a short time interval, with some participants expressing uncertainty about their approaches.
Some participants have provided guidance on calculating angular position and converting it into Cartesian coordinates. There is acknowledgment of differing results in calculations, and a participant identifies an error in their approach, leading to a revised method for determining position.
Participants are working within the constraints of a homework problem, focusing on the physics of charged particles in magnetic fields without the influence of relativistic effects. The discussion includes considerations of angular motion and the relationship between linear and angular quantities.
JonathanH13
I am having trouble with a basic deflection problem - a single proton traveling through a magnetic field:
v = Velocity of the proton = 6 000 000 meters per second (1/50th the speed of light, so no relativistic effects)
B = magnetic field strength = 0.5 Tesla
Charge of proton q = + 1.60217e-19 Coulombs
Mass of proton m = 1.67262e-27 kg
Direction = zero radians
Force = q*v*B sin(theta)
Radius=(Mass*sqr(Velocity))/Force
Period:=(2*pi*Radius)/Velocity
Force=Mass*Acceleration
First I find the maximum force on the proton due to its charge and velocity through the field:
In this case the proton is traveling perpendicular to the field, so sin(theta) = 1
and the magnitude of the force is simply:
Force = q*v*B
= 4.8065e-13 Newtons
Now that is fine, and if I want the radius of the circle described by the proton in the field I can use:
Radius=(Mass*sqr(Velocity))/Force or r=mv/qB
= 0.125 meters or 125mm
Which is particularly satisfying, because it relates such high speed, low mass and charge into a realistic spatial dimension.
I can also find the time that it takes to complete one revolution:
=131.19e-9 seconds or 131 nanoseconds.
But what I would like to find is the instantaneous position and direction after a given time, say 1 nanosecond.
I tried dividing the circumference by 131 nanoseconds, but I feel like this is cheating. :frown:
I also tried to use
Acceleration = Force/mass, but in this case the acceleration is only a change in direction, not in velocity. :confused:
I also tried to use
It is no cheating if you calculate the angular position as
alpha = 2pi*(t/T). And you know that the proton moves along a circle with constant speed, so the velocity vector is tangent to the circle. Knowing alpha, you also get the direction of the velocity.
ehild
Thanks for your reply. You describe angular position, but I require cartesian coordinates in order to simulate this:
I calculate alpha = 2pi*(t/T), using t = 1e-9 (1 nanosecond), and T (Period of one revolution) = 131.19e-9 seconds
This gives me an alpha of 0.0478 (is that in Radians?)
To attempt to convert that into an instantaneous position (my original problem),
I use Y = Sin(alpha)*Radius and X = Cos(alpha)*Radius
So, in in one nanosecond the proton is now at:
X = 0.1258 meters
Y = 0.00599 meters
Is that correct?
it is correct, but I got x=0.1248 m.
ehild
Ah, I think I see the error with my calculation.
I am now using X = Cos(alpha)*(Velocity*1e-9)
That is, if velocity is distance per second, and I require distance per nanosecond, hence(Velocity*1e-9). This delivers x and y values that describe a circle with the correct radius!
Thanks!
  • · Replies 31 ·
  • · Replies 21 ·
