Directional statistics - Entropy of wrapped normal (Jacobi theta) distribution
The discussion focuses on calculating the differential entropy of the wrapped normal distribution, specifically using the Jacobi theta function. The wrapped distribution is defined as p_w(θ) = ∑_{n=-∞}^∞ p(θ + 2πn), which is periodic with a period of 2π. The entropy formula is given by H = -∫_Γ p_w(θ) ln[p_w(θ)] dθ, where Γ is an interval of length 2π. The wrapped normal distribution with zero mean is represented as p_w(θ) = (1/2π) * θ_3(θ/2, e^{-σ²/2}), where θ_3 is the Jacobi theta function. Users are seeking guidance on calculating this entropy, as Mathematica does not provide sufficient assistance.
  • Understanding of probability distributions, specifically the wrapped normal distribution.
  • Familiarity with Jacobi theta functions and their properties.
  • Knowledge of differential entropy and its mathematical formulation.
  • Experience with numerical integration techniques for complex functions.
  • Research the properties and applications of Jacobi theta functions in statistical mechanics.
  • Learn about numerical integration methods suitable for calculating entropy in complex distributions.
  • Explore asymptotic expansions and their use in approximating entropy for wrapped distributions.
  • Investigate alternative software tools or libraries that can assist in symbolic computation for entropy calculations.
Mathematicians, statisticians, and researchers in fields involving probability theory and statistical mechanics, particularly those working with wrapped distributions and entropy calculations.
Rap
If p(x) is a probability distribution on the real number line, the "wrapped" distribution around the unit circle is:
[tex]p_w(\theta)=\sum_{n=-\infty}^\infty p(\theta+2\pi n)[/tex]
which is periodic with period 2π. The (differential) entropy is:
[tex]H=-\int_\Gamma p_w(\theta)\ln[p_w(\theta)]\,d\theta[/tex]
where [itex]\Gamma[/itex] is any interval of length 2π. I am having trouble finding the entropy for the wrapped normal distribution. For the wrapped normal distribution with zero mean,
[tex]p_w(\theta)=\frac{\vartheta _3\left(\frac{\theta }{2},e^{-\frac{\sigma ^2}{2}}\right)}{2 \pi }[/tex]
which is in Mathematica notation, [itex]\vartheta _3(\cdot)[/itex] is the Jacobi theta function:
[tex]\vartheta _3(u,q)=1+2\sum_{n=1}^\infty q^{n^2}\cos(2nu)[/tex]
Is anyone familiar enough with Jacobi theta functions to give some guidance in calculating the entropy? Mathematica is not giving much help.
You'd be lucky if a closed form expression exists. Perhaps try numerical integration or an asymptotic expansion?
  • · Replies 25 ·
