DC Motor RPM Equation Confusion
2 replies · 12K views
Blues_MTA
According to http://www.aveox.com/DC.aspx" The way to calculate the output of a DC motor in kRPMs is the formula
RPM of motor: kRPM = (V - RmI) / Kb
V= Voltage
Rm = Terminal Resistance
I = Current
Kb = Voltage Constant (V/kRPMs)
This insinuates that an increase in amperage leads to a decrease in RPMs? How is that Possible?
I know that Current:Torque and Voltage:Speed, but isn't Voltage = I*R, so an increase in current should consequently lead to an incresed voltage?
You should read up on back emf of a dc motor. As rpm increases, an opposing voltage aka back emf (@ the armature terminal) will also increases. The back emf opposes the supply voltage and thus reduces the current to the dc motor. Less rpm = less back emf = more current.
Yes, the equation shows that if the current increases, all other variables remaining constant, that the speed decreases. The causality is actually the other way around however. If you increase the load (torque) then the speed decreases and this causes the current to increase.
