How Can I Integrate Arctan for Smectic A Liquid Crystal Undulations?
  • Context: Graduate
  • Thread starter Thread starter AllanGH
    Integration
This discussion focuses on integrating the arctan function to calculate undulations in smectic A liquid crystals across multiple dimensions. The primary equation for d dimensions is presented, followed by a specific case for 2 dimensions that incorporates the arctan function. The user seeks assistance with two integral calculations: one involving arctan and another involving a square root function. The integration results can be found using Wolfram Alpha.
  • Understanding of liquid crystal physics, specifically smectic A phases
  • Familiarity with integral calculus, particularly involving arctan and square root functions
  • Knowledge of statistical mechanics concepts like k_BT and B
  • Experience with mathematical software tools such as Wolfram Alpha for complex integrations
  • Research advanced integration techniques for arctan functions
  • Explore the application of statistical mechanics in liquid crystal theory
  • Learn about numerical methods for evaluating integrals in multiple dimensions
  • Investigate the use of mathematical handbooks, such as Abramowitz' Handbook of Mathematical Functions, for reference
Researchers and students in condensed matter physics, particularly those studying liquid crystals, as well as mathematicians focusing on integral calculus and its applications in physical sciences.
AllanGH
Hi!
I am trying to calculate undulations for a smectic A liquid crystal for 1,..,4 dimensions. The general equation for [itex]d[/itex] dimensions are
[itex]\langle u^2(\mathbf{x})\rangle = \frac{k_BT}{(2\pi)^dB} \int_\frac{1}{L}^{q_c}\frac{\text{d}q_\parallel \text{d}^dq_\perp}{q_\parallel+\lambda^2q_\perp^4} [/itex]
my problem (so far) is for 2 dimensions:
approximately the problem reduces to
[itex] \langle u^2(\mathbf{x})\rangle = \frac{k_BT}{(2\pi)^dB} \int_\frac{1}{L}^{q_c}\text{d}q_\perp\, \arctan\left(\frac{q_c}{\lambda q_\perp^2}\right)\frac{1}{\lambda q_\perp^2}[/itex]
or, eventually, is there a more clever way to use the first equation? I have tried to use subs with the arctan function and partial integration.
With help from Abramowitz' Handbook of Mathical Function the second equation can be written as
[itex] \langle u^2(\mathbf{x})\rangle =-\frac{\lambda}{q_c}\left(\frac{q_c}{\lambda}\right)^{3/2} \frac{k_BT}{(2\pi)^dB} \left[2\sqrt{q_\perp} \arctan{q_c} - 2\int\frac{\sqrt{q_\perp}\text{d}q_\perp}{1+ q_\perp^2}\right][/itex]
but I think I am moving in circles now.. so my problem is basically to calculate either
[itex] \int\text{d}x\arctan(a/x^2)\frac{1}{x^2}[/itex]
or
[itex] \int\frac{\text{d}x \sqrt{x}}{1+x^2}[/itex]
will be grateful for some help! :)
Al
