Gravitational force between everyday objects
The discussion centers around the gravitational force between everyday objects, exploring why this force is not observable in daily life despite the principle that all objects attract each other. The conversation touches on theoretical aspects and practical implications of gravitational interactions.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant questions why everyday objects do not appear to attract each other, referencing Cavendish's experiment as a point of confusion.
  • Another participant explains that gravitational force is extremely weak compared to other forces, which typically dominate interactions between everyday objects.
  • It is noted that the gravitational pull of the Earth, while significant, is still relatively weak when compared to the forces acting on smaller masses.
  • A participant mentions that even on a near frictionless surface, the gravitational force is insufficient to overcome static friction between large objects, such as two 1000 kg masses.
  • A later reply expresses gratitude for the clarifications provided by other participants.
Participants generally agree that the gravitational force is weak and that other forces overshadow it in everyday scenarios. However, the initial question about the visibility of gravitational attraction remains a point of exploration without a definitive resolution.
The discussion does not delve into the specific mathematical formulations of gravitational force or the conditions under which it becomes noticeable, leaving some assumptions and definitions unaddressed.
quantizedzeus
Gravitational force between everyday objects...
I know It's a common question...but i could not find satisfactory answer...the question is "if every objects are attracting each others then why don't we see the daily objects attracting each others...?? Then how could Cavendish make his experiment...??...
The gravitational force is extremely weak. As such, other forces usually completely overwhelm the gravitational force between everyday objects.
Just think, you have the entire Earth pulling down on you, and yet it is still relatively easy to jump and walk around.
Cavendish used extremely sensitive measurements to do his experiments.
See: http://en.wikipedia.org/wiki/Cavendish_experiment
Like Matterwave said, the force of gravity is extremely weak for objects with masses near ourselves and everyday objects. If they entire mass of the Earth only pulls us down at 9.8 m/s^2, an object a few billion times less massive or more wouldn't be noticeable at all.
even on a near frictionless surface like ice, two 1000 kg wouldn't make it to each other because the force of static friction is more then gravity can overcome. Thats why you don't see two coffee mugs sliding towards each other in your kitchen
Oh...thanks everyone..this is what i wanted to know ...
  • · Replies 51 ·
  • · Replies 29 ·
  • · Replies 29 ·
  • · Replies 33 ·
