Speed of Ball Attached to Horizontal Cord
The speed of a ball attached to a horizontal cord of length L at the lowest point of its path is calculated using the equation v = sqrt(2gr), where g is the acceleration due to gravity (9.8 m/s²). When the ball reaches the top of its circular path about a peg located at a distance h (0.80L) below the attachment point, its speed can be determined using conservation of energy principles, resulting in v = sqrt(1.6gL). Both calculations demonstrate the relationship between the length of the cord and the speed of the ball at different points in its trajectory.
  • Understanding of basic physics concepts, specifically kinetic and potential energy.
  • Familiarity with the conservation of energy principle.
  • Knowledge of gravitational acceleration (g = 9.8 m/s²).
  • Ability to manipulate algebraic equations for solving for variables.
  • Study the principles of conservation of mechanical energy in physics.
  • Learn about the dynamics of pendulum motion and circular motion.
  • Explore the effects of varying lengths of pendulums on their speed and energy.
  • Investigate real-world applications of pendulum mechanics in engineering and design.
Students of physics, educators teaching mechanics, and anyone interested in understanding the dynamics of pendulum motion and energy conservation principles.
Soaring Crane
A ball is attached to a horizontal cord of length L whose other end is fixed.
a. If the ball is released what will be its speed at the lowest point of its path?
(1/2)mv^2 = mgr, or v^2 = 2gr, v = sqrt(2gr)?
b. A peg is located a distance h directly below the point of attachment of the cord. If h = 0.80 L, what will be the speed of the ball when it reaches the top of its circular path about the peg?
pic:
O_____L________o
--+--------------|h
----+------------*peg--+
---------+----+-O--+
+ = path of circular motion
O = ball
Any help to start is appreciated.
The first one is correct.(r=L).
When the ball reaches its top circular path, it has both kinetic energy and potential energy.
Initial energy,E(initial) = mgL
Total energy when the ball reaches its top circular path,E(final) = [tex]\frac{1}{2}mv^2 + mg*2(L-h).[/tex]
Law of conservation of energy : E(initial) = E(final)
a. The speed of the ball at the lowest point of its path can be calculated using the equation (1/2)mv^2 = mgr, where m is the mass of the ball, v is its speed, g is the acceleration due to gravity, and r is the distance from the point of attachment to the lowest point of the ball's path. Since the ball is released from rest, its initial velocity is 0, and the equation simplifies to v^2 = 2gr. Plugging in the values for g (9.8 m/s^2) and r (L, the length of the cord), we get v = sqrt(2gr). This means that the speed of the ball at the lowest point of its path will depend on the length of the cord.
b. To calculate the speed of the ball when it reaches the top of its circular path about the peg, we can use the conservation of energy principle. At the top of the path, the ball has both kinetic energy (due to its speed) and potential energy (due to its height above the ground). The total energy is equal to the sum of these two energies. We can set this equal to the energy at the bottom of the path, which is only kinetic energy (since the ball is released from rest). The equation is written as (1/2)mv^2 + mgh = (1/2)mv^2, where m is the mass of the ball, v is its speed, g is the acceleration due to gravity, h is the height of the ball above the ground, and r is the radius of the circular path. We can rearrange this equation to solve for v, which gives us v = sqrt(2gh). Since h = 0.80L, we get v = sqrt(2g(0.80L)) = sqrt(1.6gL). This means that the speed of the ball when it reaches the top of its circular path about the peg will also depend on the length of the cord.
  • · Replies 24 ·
  • · Replies 38 ·
